Yes the config is formated in the web editor.
Sorry the formatting was removed when I pasted it here in the forum
very strange.
i check in the web inspector of firefox.
the config parameter of period is actually applied in the url. Means the {periode} is replace with the corresponding time range.
i also checked with the standard web widget in OH3 UI and added the non embedded URL. here the time range adapts.
seems to be a issue only on the embedded link of grafana
Try removing %2B56h from the URL. This looks strange to me.
this i tried already and it had not influence on the time switching
As i like to visualize data in the future an add 56h
â+â is not accepted ad character thatâs why it is %2B
once again the replacement of period is working. the selected time range is visuable when I investigate the html of the OH UI.
I guess it must be something in grafana then
What do I need to do, so I can display Grafana dashboards without login?
edit grafana.ini:
[auth.anonymous]
# enable anonymous access
enabled = true
Then restart grafana.
Ok sounds logic to me, but by setting this, my whole Grafana environment will be accessible without password? Although itâs only available from my local network, this doesnât sound very secure.
I will give it a try.
Did it work?
no still the same message. I also checked if allow_embedding
was turned on, but this is also the case.
What version are you using?
I am on 7.5.2.
I have just upgraded grafana to 7.5.7 and it is working OK.
Just to test:
If you have a web page of grafana that works in a browser you can copy that url and put that into the widget just to test the widget.
You have to also put the time range options in as well otherwise the widget wonât work and you will see the content is blocked screen.
If this works then you should be good to get the syntax of the time ranges to work.
Below is what I mean:
The url I used is one that works in the browser.
Good luck.
Iâm on 7.5.3
I can open this page without any issues in my browser http://192.168.0.4:3000/d/6gOBMstMz/overview?orgId=1
, but not working in the widget.
I also tried it via a oh-webframe
component, I can show eg my zigbee2mqtt dashboard, but not Grafana.
In the grafana.ini did you also set:
# set to true if you want to allow browsers to render Grafana in a <frame>, <iframe>, <embed> or <object>. default is false.
allow_embedding = true
And then restart grafana.
I had this line in my .ini file, but my docker container wasnât using this file⊠no everything works fine! thanks
Great widget!
How could I add a âpreviousâ and ânextâ button to the time periods?
For example, Iâd like to look at 1 day range, but skip back and forward days
Hi Marcus,
thank you for the widget. I am one step closer now.
My goal would be to replace the OH3 Graphs with Grafana.
Right now i have a labeled button:
and when I click on it the OH3 chart is displayed on the available screen:
I have modified your widget to:
component: oh-label-cell
title: =props.vTitel
icon: oh:chart
item: gHeizung_Stellwerte
trendItem: Heizung_Vorlauftemperatur_Ist
slots:
default:
- component: oh-webframe-card
borders: false
class:
- display-block
footer: =props.footer
height: =props.height
noBorder: false
outline: true
src: =props.URL.replace('{period}', vars.selectedPeriod || [props.timerange.split(',')[0].split('=')[0]])
title: =props.title
- component: f7-segmented
outline: false
round: false
style:
--f7-segmented-strong-between-buttons: 5px
--f7-segmented-strong-bg-color: rgba(255, 255, 255, 0.05)
--f7-segmented-strong-button-font-weight: 300
--f7-segmented-strong-button-hover-bg-color: rgba(255, 255, 255, 0.07)
--f7-segmented-strong-padding: 0px
slots:
default:
- component: oh-repeater
for: size
fragment: true
sourceType: range
slots:
default:
for: period
fragment: true
in: =[props.timerange.split(",")[loop.size].split("=")[1]]
slots:
default:
- component: oh-button
action: variable
actionVariable: selectedPeriod
actionVariableValue: =props.timerange.split(",")[loop.size].split("=")[0]
fill: "=(([props.timerange.split(',')[loop.size].split('=')[0]] == vars.selectedPeriod) || (props.timerange.split(',')[0].split('=')[1] === loop.period) && !vars.selectedPeriod) ? true : false"
outline: true
round: false
style:
--f7-button-border-color: rgba(255,255,255,15)
--f7-button-border-radius: 5px
--f7-button-border-width: 1px
--f7-button-fill-hover-bg-color: rgba(var(--f7-theme-color-rgb), 1)
--f7-button-font-size: 14px
--f7-button-font-weight: 300
--f7-button-padding-horizontal: 0px
--f7-button-padding-vertical: 0px
--f7-button-text-color: black
--f7-button-text-transform: none
text: =loop.period
When clicking the button it looks:
So the main difference to the OH3 chart is that the popup is not covering the full page, the grafana chart is not in the centre and for any reasons the select buttons are above the graph.
Do you have an idea on how to proceed here?
Marco
Hi Marco,
I suppose that the problem is related to
whereas I am using
Need to state that Iâm not a f7 expert at all - lots of trial and error when I built this widget.
Good luck!
Marcus
Not sure this is easy to implement.
You might want to take a quick look here:
It is using 1:1 the logic from grafana e.g.:
from=now-1d&to=now
⊠maybe something to get started with and add some code to make this work for you.
My skills are not sufficient to do this. Maybe someone else can help.
Please share your code once implemented. Thanks!
Good luck!
Unfortunately trial and error is my approach too when it comes to widget design
Hopefully someone with more skill jumps on this topic.
BR
Marco
