- Platform information:
- Hardware: RPI4 -4GBRAM
- OS: Openhabian 1.6
- Java Runtime Environment: Azul 8
- openHAB version: stable
Hello, I wanted to migrate to full USB boot on my RPI4- as a linux noob. I backedup my config then imaged the Openhabian 1.6 on a SD card and ran it and installed initial updates etc. so it boots. Then I copied this with SD Card copier form another Linux machine to USB drive. It boots fine from the USB drive. I then installed mqtt from openhabian-config- but that gave me also errors during install- it did not complete which I could fix with this
[Openhabian - Mosquitto MQTT failed to start]
So my mqtt is now working (THX @mstormi )
Now I wanted to setup Grafana and influxdb. I actually did this before I restored my backup and I saw the “grafana” page other the openhab start screen on 8080. So it seemed to have worked before the backup. After the backup- the grafana window does not show up on 8080.
I tried “fix permissions” and reinstall grafana and Influx from openhabian-config -but it is not working, it errors out. I have no idea… I am not a linux guy… if anyone could give me a hint - that be awesome!
cheers
:09:31] openhabian@openhab:~$ sudo systemctl status grafana-server.service
● grafana-server.service - Grafana instance
Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2020-11-29 18:09:15 CET; 32s ago
Docs: http://docs.grafana.org
Process: 10012 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packaging=deb cfg:default.paths.logs=${LOG_DIR} cfg:default.paths.da
Main PID: 10012 (code=exited, status=1/FAILURE)
Nov 29 18:09:15 openhab systemd[1]: grafana-server.service: Service RestartSec=100ms expired, scheduling restart.
Nov 29 18:09:15 openhab systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
Nov 29 18:09:15 openhab systemd[1]: Stopped Grafana instance.
Nov 29 18:09:15 openhab systemd[1]: grafana-server.service: Start request repeated too quickly.
Nov 29 18:09:15 openhab systemd[1]: grafana-server.service: Failed with result 'exit-code'.
Nov 29 18:09:15 openhab systemd[1]: Failed to start Grafana instance.
Nov 29 17:44:17 openhab systemd[1]: grafana-server.service: Failed with result 'exit-code'.
Nov 29 17:44:17 openhab systemd[1]: grafana-server.service: Service RestartSec=100ms expired, scheduling restart.
Nov 29 17:44:17 openhab systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
Nov 29 17:44:17 openhab systemd[1]: Stopped Grafana instance.
Nov 29 17:44:17 openhab systemd[1]: grafana-server.service: Start request repeated too quickly.
