I have just gotten grafana and influxdb up and running and I am very new to openHAB and coding in general. Grafana works and is charting the data correctly. I followed the steps on the tutorial post but when I get to adding grafana to basic ui I can’t get them to display they just say error not found or not available. I have gone through and set allow_embedding = true in the grafana.ini but that doesn’t help ideally I’d set up grafana to show in basic ui by using @wborn method but I can’t even get the simplest way to work. Has anyone else had the same problem and know a way to fix it?
