In the frame I get the same thing - it flickers, sometimes it manages to render the title before reload.
I’ve tried this with and without cookies and in chrome, FF, Edge and IE.
Unfortunately it does not work, even making allow_embedding=true
Using Grafana 6.2.2 with HABPanel. None of the graphs are being shown.
Link in the browser is displayed perfectly. In HABPanel does not work.
No nice graphs indeed…
I’m having the same problem as well, tried the fix of @FutureCow but that didn’t fixed the issue in my case, does anybody has another fix that we could try?
I think you have the same problem, grafana is blocking iframe.
You put the allow_embedding=true under security in the ini file?
Have you installed grafana with a package? You edit the right ini file? Restarted grafana? Check some logs of grafana, you might find some more info.
@Stehof
indeed! Works for me as well now. Question for 100 Points. Who the heck comments with ; the line? All files I worked so far under linux were commented by #. This made me confused.
# set to true if you want to allow browsers to render Grafana in a <frame>, <iframe>, <embed> or <object>. $
#;allow_embedding = false --> orginal line
allow_embedding = true
Another hint from my side:
please make sure your browser is not blocking scripts. It took me also a while to remove this blocker…
Thanks everybody for support!
@wiewior great that it’s working for you as well, indeed pretty confusing that all the script comment there lines with # and in grafana suddenly uses a ;
