- Platform information:
- Hardware: Raspberry Pi 4
- OS: Raspbian 10
- Java Runtime Environment: Zulu11.43+100-CA (build 11.0.9.1+1-LTS)
- openHAB version: 3.0.0
- Issue of the topic: I had a functional openhab2 install but I purged it from the system and installed Openhab 3 from apt. I also installed Zulu 11. I was able to get start the openhab service and access the web interface to set up an openhab admin user. Once I go to log in with the openhab admin user I get a 404 error. The openhab log reads out:
18:46:03.198 [DEBUG] [auth.internal.AbstractAuthPageServlet] - Login successful: openhabAdmin
18:46:03.201 [TRACE] [ore.storage.json.internal.JsonStorage] - deserialized value ‘openhabAdmin (administrator)’ from Json
18:46:03.204 [TRACE] [ore.storage.json.internal.JsonStorage] - deserialized value ‘openhabAdmin (administrator)’ from Json
18:46:03.207 [DEBUG] [mmon.registry.AbstractManagedProvider] - Updated element openhabAdmin in ManagedUserProvider.
18:46:03.549 [WARN ] [e.io.rest.auth.internal.TokenResource] - PKCE verification failed
18:46:03.551 [WARN ] [e.io.rest.auth.internal.TokenResource] - Token issuing failed: invalid_grant
It looks like perhaps it’s an issue with openhab accessing Java? Is this a known issue? How can I troubleshoot?
This Raspberry Pi is configured to server several other functions and so I’m trying to avoid wiping it for openhabian.
Thanks!
