Greenwave PowerNode 6?
Hello!
Has anybody had any experience with the Greenwave Powernode 6 Power Strip? Pepper DB PowerNode
I am looking for a controllable Power Strip to put behind my Living room entertainment center and that one stood out as the cheapest…
Bye, Frido.
Hi Frido,
I have the Greenwave Powernode 6 and it’s working very well. There are two things you have to be aware of however:
  • the state of the different nodes is not automatically updated, so you need to poll every single node in order to get the correct state
  • after a powerfailure, all nodes default to On
Beside these two drawbacks, I am very satisfied with this device.
Regards,
Matt
Just wanted to post the same thing :smile:
Didn’t know about the second issue, good to know.
I have 1 for a few years, and it works fine.
Also have the single node version which also works fine.
Thanks for the replies. How do I poll the nodes in openHAB? Do I simply use a rule to get the state every x seconds?
Bye, frido.
No - you can’t do this. Just add the refresh_interval parameter to the end of the item configuration (check the wiki).
Chris
Thank you all, then I’ll buy it and try it out.
Bye, frido.
Just to close this topic:
Bought the device, works fine, sample config will follow as soon as I get home…
Bye, Frido.
Have you been able to get power meter reading from all 6 outlets?
I just have 2 of Turm in use at the moment, but get readings from all 6 of them…
Bye, Frido.
Good to hear.
I am using Vera Edge and I cannot get readings correctly for energy from the Greenwave Powernode 6 Power Strip.within Vera.
I have plan to use a Zwave stick and OpenHab and maybe I can get it to work then
thanks
