I’m using the GroheOndus Binding together with my Grohe SenseGuard. I can login to my Grohe account and my binding is pulling the data from the API.
Unfortunately the binding is not pulling the data again in the polling time interval. I have to manually disable and activate the binding to pull the actual values (like you can see in the chart below).
I tried uninsalling and reinstalling the binding, did not help. Refresh token is set and account credentials are given.
All I can see in the log files is the following. The java error messages only show up at the first starting, after that, everything looks fine, bridge is online and SenseGuard too.
2021-04-29 08:20:01.706 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘groheondus:account:8a040c38be’ changed from UNINITIALIZED (DISABLED) to INITIALIZING
2021-04-29 08:20:01.727 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘groheondus:account:8a040c38be’ changed from INITIALIZING to UNKNOWN
2021-04-29 08:20:03.072 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.groheondus.internal.handler.GroheOndusBaseHandler.getRoom(GroheOndusBaseHandler.java:135) ~[?:?]
at org.openhab.binding.groheondus.internal.handler.GroheOndusBaseHandler.getAppliance(GroheOndusBaseHandler.java:144) ~[?:?]
at org.openhab.binding.groheondus.internal.handler.GroheOndusBaseHandler.updateChannels(GroheOndusBaseHandler.java:102) ~[?:?]
at org.openhab.binding.groheondus.internal.handler.GroheOndusAccountHandler.lambda$2(GroheOndusAccountHandler.java:154) ~[?:?]
at java.util.ArrayList.forEach(ArrayList.java:1541) ~[?:?]
at java.util.Collections$UnmodifiableCollection.forEach(Collections.java:1085) ~[?:?]
at org.openhab.binding.groheondus.internal.handler.GroheOndusAccountHandler.lambda$1(GroheOndusAccountHandler.java:151) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
2021-04-29 08:20:03.072 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘groheondus:account:8a040c38be’ changed from UNKNOWN to ONLINE
2021-04-29 08:30:12.307 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GroheOndusSenseGuardHandler of thing groheondus:senseguard:8a040c38be:e95c8f14-e75c-4aaa-bec5-a0767544612b tried accessing its bridge although the handler was already disposed.
2021-04-29 08:30:12.309 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GroheOndusSenseGuardHandler tried updating the thing status although the handler was already disposed.
