I’ve recently purchased a security shutoff valve from Grohe and it is connected via the Grohe Ondus App. A big part of me selecting this brand was due to the binding in OH But when I try to create the “brigde” I get “Unknown response with code 404”. Am I doing something wrong?
From the log:
2019-03-06 14:14:31.713 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'groheondus:account:23612344': Unknown response with code 404
java.lang.IllegalArgumentException: Unknown response with code 404
at org.grohe.ondus.api.actions.LoginAction.lambda$getToken$7(LoginAction.java:25) ~[?:?]
at java.util.Optional.orElseThrow(Optional.java:290) ~[?:?]
at org.grohe.ondus.api.actions.LoginAction.getToken(LoginAction.java:24) ~[?:?]
at org.grohe.ondus.api.OndusService.login(OndusService.java:45) ~[?:?]
at org.grohe.ondus.api.OndusService.login(OndusService.java:37) ~[?:?]
at org.openhab.binding.groheondus.internal.handler.GroheOndusAccountHandler.initialize(GroheOndusAccountHandler.java:69) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.oh240]
I tried to reinstall the binding and got some more log errors. But it doesn’t help me…
2019-03-06 14:38:39.097 [INFO ] [org.openhab.binding.groheondus ] - FrameworkEvent INFO - org.openhab.binding.groheondus
java.io.IOException: Exception in opening zip file: /var/lib/openhab2/cache/org.eclipse.osgi/223/0/bundleFile
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:321) ~[?:?]
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.basicOpen(ZipBundleFile.java:93) ~[?:?]
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.getZipFile(ZipBundleFile.java:106) ~[?:?]
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.checkedOpen(ZipBundleFile.java:65) ~[?:?]
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.getEntry(ZipBundleFile.java:240) ~[?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:560) ~[?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:538) ~[?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:525) ~[?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:446) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[?:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:?]
at java.lang.Class.forName0(Native Method) ~[?:?]
at java.lang.Class.forName(Class.java:348) ~[?:?]
at org.apache.commons.logging.impl.LogFactoryImpl.createLogFromClass(LogFactoryImpl.java:998) ~[?:?]
at org.apache.commons.logging.impl.LogFactoryImpl.discoverLogImplementation(LogFactoryImpl.java:844) ~[?:?]
at org.apache.commons.logging.impl.LogFactoryImpl.newInstance(LogFactoryImpl.java:541) ~[?:?]
at org.apache.commons.logging.impl.LogFactoryImpl.getInstance(LogFactoryImpl.java:292) ~[?:?]
at org.apache.commons.logging.impl.LogFactoryImpl.getInstance(LogFactoryImpl.java:269) ~[?:?]
at org.apache.commons.logging.LogFactory.getLog(LogFactory.java:655) ~[6:org.ops4j.pax.logging.pax-logging-api:1.10.1]
at org.apache.http.conn.ssl.DefaultHostnameVerifier.<init>(DefaultHostnameVerifier.java:82) ~[?:?]
at org.apache.http.impl.client.HttpClientBuilder.build(HttpClientBuilder.java:955) ~[?:?]
at org.apache.http.impl.client.HttpClients.createDefault(HttpClients.java:56) ~[?:?]
at org.grohe.ondus.api.client.ApiClient.<init>(ApiClient.java:28) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:?]
at java.lang.Thread.run(Thread.java:748) ~[?:?]
Caused by: java.io.FileNotFoundException: /var/lib/openhab2/cache/org.eclipse.osgi/223/0/bundleFile (No such file or directory)
at java.util.zip.ZipFile.open(Native Method) ~[?:?]
at java.util.zip.ZipFile.<init>(ZipFile.java:225) ~[?:?]
at java.util.zip.ZipFile.<init>(ZipFile.java:155) ~[?:?]
at java.util.zip.ZipFile.<init>(ZipFile.java:169) ~[?:?]
at org.eclipse.osgi.framework.util.SecureAction$16.run(SecureAction.java:308) ~[?:?]
at org.eclipse.osgi.framework.util.SecureAction$16.run(SecureAction.java:1) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:306) ~[?:?]
... 38 more
2019-03-06 14:38:39.185 [INFO ] [org.openhab.binding.groheondus ] - FrameworkEvent INFO - org.openhab.binding.groheondus
java.io.IOException: Exception in opening zip file: /var/lib/openhab2/cache/org.eclipse.osgi/223/0/.cp/lib/ondus-api-0.0.4.jar
Caused by: java.io.FileNotFoundException: /var/lib/openhab2/cache/org.eclipse.osgi/223/0/.cp/lib/ondus-api-0.0.4.jar (No such file or directory)
... 38 more
2019-03-06 14:38:41.661 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.groheondus.internal.handler.GroheOndusAccountHandler@1e188844': Unknown response with code 404
2019-03-06 14:38:41.672 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'groheondus:account:c9d773e7': Unknown response with code 404
- Platform information:
- OS: Debian 9.4 64-bit
- Java Runtime Environment: build 1.8.0_181-b13
- openHAB version: 2.4.0
