masterpe
(masterpe)
October 5, 2015, 8:14am
#1
I have an TKB Home TZ66D Z-Wave Wall Switch, this switch has an local and an remote button. It can send commands to 4 associations groups. When I press the local button (group 1), the light go’s on. On the item:
Switch main_switch_slaapkamer (Slaapkamerswitch) { zwave=“10:command=SWITCH_BINARY”}
The switch does not change. When I send an ON or OFF command to main_switch_slaapkamer, the light go’s on or off.
But how do I receive the group command from the buttons to openhab?
Vini
(Vini)
January 2, 2016, 11:39pm
#2
Sorry to bump such an old thread, but I’m having the same problems… I suspect it’s a misconfiguration of my item…
item.items
Switch Z_Light_FF_FrontBedroomSwitch "Bedroom: Light" (FF_BackBedroom) { zwave="10:command=SWITCH_BINARY" }
rule.rules
rule “Turn Front Bedroom Light on (zwave test)”
Item Z_Light_FF_FrontBedroomSwitch received command ON
sendCommand(Z_Socket_FrontBedroom_DAB, ON)
sendCommand(Z_Socket_FrontBedroom_Morning, ON)
rule "Turn Front Bedroom Light on (zwave test off)"
Item Z_Light_FF_FrontBedroomSwitch received command OFF
sendCommand(Z_Socket_FrontBedroom_DAB, OFF)
sendCommand(Z_Socket_FrontBedroom_Morning, OFF)
zwave.log
2016-01-02 22:44:33.417 [DEBUG] [.ApplicationUpdateMessageClass:44 ]- NODE 10: Application update request. Node information received.
2016-01-02 22:44:33.417 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ]- Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 05 01 00
2016-01-02 22:44:33.417 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ]- Recv message Message: class = ApplicationUpdate (0x49), type = Request (0x00), payload = 84 0A 0A 04 10 01 25 85 27 70 73 86 72
2016-01-02 22:44:33.417 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ]- Checking transaction complete: class=ApplicationUpdate, expected=SendData, cancelled=false
2016-01-02 22:44:33.489 [DEBUG] [eController$ZWaveReceiveThread:1441]- Receive Message = 01 09 00 04 00 0A 03 20 01 00 DA
2016-01-02 22:44:33.490 [DEBUG] [eController$ZWaveReceiveThread:1365]- Receive queue ADD: Length=1
2016-01-02 22:44:33.492 [DEBUG] [b.z.i.protocol.ZWaveController:1123]- Receive queue TAKE: Length=0
2016-01-02 22:44:33.492 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 09 00 04 00 0A 03 20 01 00 DA
2016-01-02 22:44:33.492 [DEBUG] [b.z.i.protocol.ZWaveController:1124]- Process Message = 01 09 00 04 00 0A 03 20 01 00 DA
2016-01-02 22:44:33.493 [DEBUG] [b.z.i.protocol.ZWaveController:190 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 0A 03 20 01 00
2016-01-02 22:44:33.493 [DEBUG] [ApplicationCommandMessageClass:38 ]- NODE 10: Application Command Request (ALIVE:DONE)
2016-01-02 22:44:33.493 [DEBUG] [ApplicationCommandMessageClass:56 ]- NODE 10: Incoming command class BASIC
2016-01-02 22:44:33.493 [DEBUG] [z.i.p.c.ZWaveBasicCommandClass:74 ]- NODE 10: Received Basic Request
2016-01-02 22:44:33.493 [DEBUG] [z.i.p.c.ZWaveBasicCommandClass:78 ]- NODE 10: Basic Set sent to the controller will be processed as Basic Report
2016-01-02 22:44:33.493 [DEBUG] [z.i.p.c.ZWaveBasicCommandClass:107 ]- NODE 10: Basic report, value = 0x00
2016-01-02 22:44:33.493 [DEBUG] [b.z.i.protocol.ZWaveController:595 ]- Notifying event listeners: ZWaveCommandClassValueEvent
2016-01-02 22:44:33.493 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2016-01-02 22:44:33.493 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 10: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 0
2016-01-02 22:44:33.493 [DEBUG] [ApplicationCommandMessageClass:85 ]- Transaction not completed: node address inconsistent.
Any ideas? I’ve tried changing the item through, BASIC, SWITCH_BASIC, SWITCH_BINARY with no joy
chris
(Chris Jackson)
January 3, 2016, 12:10am
#3
Since the device seems to be sending the BASIC class, so you probably need to link to this. Have you tried adding the “respond_to_basic=true” option to the end of the item config?
Vini
(Vini)
January 3, 2016, 12:56pm
#4
chris:
Hi Chris,
I had tried “, respond_to_basic=true” after the class, however, I am not sure which one I tried it with, so I tried it again…
A combination of adding “, respond_to_basic=true” and adding the devices I wanted to control, to the Association Group seems to have worked
So we now have;
item.items
Switch Z_Light_FF_FrontBedroomSwitch "Bedroom: Light" (FF_BackBedroom) { zwave="10:command=SWITCH_BINARY, respond_to_basic=true" }
rule.rules
rule "Turn Front Bedroom Toys on"
rule "Turn Front Bedroom Toys off"
and Configuration like so;
All appears well now
