I started with playing with the main ui.
The garage displays the temperature of a motion sensor
I would also like to display whether the garagedoor is open or closed.
Is there any way to do this. I’m a complete newbie to this. I wanne show the status in of the garagedoor in the “header”
You’ve not given it a tag to tell the model that it’s an Item that indicates the open/closed state of a garage door.
Use “Door” or “GarageDoor” as the Equipment tag and the Contact Item is probably OK. Though I’ve used “OpenState” as the Point tag for my garage doors.
