today I had the effect that a group of motion detectors was not switched to OFF although all members in that group were OFF. The log told that the group changed to OFF but the rule was not triggered. So I read the item’s state from the Karaf console, seeing that the group state stil was ON although all member items had the state OFF.
Only when I switched off the group item manually the rule “Presence check” checked the correct state depending on that item.
Here’s an extract from the event log:
2018-01-23 08:16:00.487 [vent.ItemStateChangedEvent] - KitchenMotion changed from ON to OFF
2018-01-23 08:16:04.718 [vent.ItemStateChangedEvent] - LivingroomMotion changed from ON to OFF
2018-01-23 08:17:06.711 [vent.ItemStateChangedEvent] - LivingroomMotion changed from OFF to ON
2018-01-23 08:17:37.703 [vent.ItemStateChangedEvent] - LivingroomMotion changed from ON to OFF
2018-01-23 08:17:44.193 [vent.ItemStateChangedEvent] - CorridorMotion changed from ON to OFF
2018-01-23 08:19:28.789 [vent.ItemStateChangedEvent] - BathroomMotion changed from ON to OFF
2018-01-23 08:19:28.792 [GroupItemStateChangedEvent] - gIndoorMotion changed from ON to OFF through BathroomMotion
Here you can see that all members of gIndoorMotion had changed to off so that as an result the log says that gIndoorMotion changed to OFF, too.
But it wasn’t really as I could see in item’s state in Karaf. Then I switched the group off manually. After that the group state was correct and the “Presence check” was triggered accordingly.
Here’s the definiton of the group:
Group:Switch:OR(ON,OFF) gIndoorMotion “Bewegungsmelder innen”
Until today morning I never had that behaviour before. But now I’m in doubt that maybe might be a bug in the current OH2 version I’m using so that presence check might not work as expected.
My current version of OH2 is 2.2.0 running on RPI3.
Here’s the rule. But the rule was not the problem. After I switched off the group item the rule was triggered as expected.
rule "Check for presence"
Time cron "0 */5 * * * ?"
if (Presence.state == ON) {
constraint_count = 0
phone_count = gMobiles.members.filter(s | s.state == ON).size
if(phone_count == 0) {
logInfo("PresenceCheck", "No phone within reach, checking for flapping")
if(gMobiles.members.filter(s | s.changedSince(now.minusMinutes(presence_timeout), "influxdb")).size == 0) {
phone_present = false
logInfo("PresenceCheck", "No phone was present during the last " + presence_timeout + " minutes")
else {
constraint_count = constraint_count + 1
phone_present = true
logInfo("PresenceCheck", "At least one phone present during the last " + presence_timeout + " minutes")
else {
if (phone_count < 2) {
phone_count_text = "is "
phone_text = " phone"
else {
phone_count_text = "are "
phone_text = " phones"
logInfo("PresenceCheck", "Currently there " + phone_count_text + phone_count + phone_text + " present")
if((gIndoorMotion.state == OFF) && (gIndoorMotion.members.filter(m | m.changedSince(now.minusMinutes(presence_timeout), "influxdb")).size == 0)) {
motion_occured = false
logInfo("PresenceCheck", "No motion occured during the last " + presence_timeout + " minutes")
else {
motion_occured = true
logInfo("PresenceCheck", "Motion occured during the last " + presence_timeout + " minutes")
if((gWeightSwitches.state == OFF) && (gWeightSwitches.members.filter(s | s.changedSince(now.minusMinutes(presence_timeout), "influxdb")).size == 0)) {
weight_on_sensor = false
logInfo("PresenceCheck", "No one sat on the sofa or laid in bed in the last " + presence_timeout + " minutes")
else {
weight_on_sensor = true
logInfo("PresenceCheck", "Somebody sat on sofa or laid in bed during the last " + presence_timeout + " minutes")
if(CorridorDoorContact.state == CLOSED ) {
door_open = false
logInfo("PresenceCheck", "Front door is closed")
else {
door_open = true
logInfo("PresenceCheck", "Front door is open")
// if((phone_present == false) && (motion_occured == false) && (door_open == false) && (weight_on_sensor == false)) {
if(constraint_count == 0) {
logInfo("PresenceCheck", "Nobody is at home: setting Presence to OFF")
sendCommand(Presence, OFF)
else {
logInfo("PresenceCheck", constraint_count + " constraints are met, somebody is at home: no further triggering")
else {
//For initialisation. If Presence is undefined or off, although it should be on.
if((gMobiles.members.filter(s | s.state == ON).size > 0) || (gIndoorMotion.members.filter(s | s.state == ON).size > 0) || (gWeightSensors.members.filter(s | s.state == ON).size > 0)) {
logInfo("PresenceCheck", "Setting presence to ON during initialisation")
sendCommand(Presence, ON)
else if (Presence.state == "Undefined" || Presence.state == "Uninitialized" || Presence.state == NULL) {
logInfo("PresenceCheck", "Presence state is UNKNOWN, setting Presence to OFF")
Here’s the group definition again: Group:Switch:OR(ON,OFF) gIndoorMotion "Bewegungsmelder innen" <motion>
Here’s the result in the log, where you can see, that my rule detects motion although there was no motion.
2018-01-23 08:55:00.151 [INFO ] [smarthome.model.script.PresenceCheck] - No phone within reach, checking for flapping
2018-01-23 08:55:00.238 [INFO ] [smarthome.model.script.PresenceCheck] - No phone was present during the last 10 minutes
2018-01-23 08:55:00.263 [INFO ] [smarthome.model.script.PresenceCheck] - Motion occured during the last 10 minutes
2018-01-23 08:55:00.364 [INFO ] [smarthome.model.script.PresenceCheck] - No one sat on the sofa or laid in bed in the last 10 minutes
2018-01-23 08:55:00.373 [INFO ] [smarthome.model.script.PresenceCheck] - Front door is closed
2018-01-23 08:55:00.379 [INFO ] [smarthome.model.script.PresenceCheck] - 1 constraints are met, somebody is at home: no further triggering
Sometimes it happen, that the group is not updated after update of items file. Write a little rule to browse members of group to verify this.
rule "Loop through groupitems"
Item swLoopThroughGroupitems changed to ON
logInfo("Logger","LoopThroughGroupitems")
logInfo("Logger","##########################################")
logInfo("Logger","gSwitches-List")
logInfo("Logger","==========================================")
gSwitches.members.forEach[item |
logInfo("Logger","gSwitches Itemname: "+item.name + ": "+ item.state.toString)
swLoopThroughGroupitems.postUpdate(OFF)
But that’s no wonder because at 09:32 I switched the group item off manually in Karaf console and as an result all group items were switched off, too:
2018-01-23 09:32:57.938 [ome.event.ItemCommandEvent] - Item 'gIndoorMotion' received command OFF
2018-01-23 09:32:57.943 [ome.event.ItemCommandEvent] - Item 'LivingroomMotion' received command OFF
2018-01-23 09:32:57.954 [ome.event.ItemCommandEvent] - Item 'KitchenMotion' received command OFF
2018-01-23 09:32:57.966 [ome.event.ItemCommandEvent] - Item 'CorridorMotion' received command OFF
2018-01-23 09:32:57.984 [ome.event.ItemCommandEvent] - Item 'BedroomMotion' received command OFF
2018-01-23 09:32:57.991 [ome.event.ItemCommandEvent] - Item 'BathroomMotion' received command OFF
And afterwards, the presence rule detected the state correctly and switched Presence to off.
2018-01-23 09:35:00.471 [vent.ItemStateChangedEvent] - Presence changed from ON to OFF
2018-01-23 09:35:00.583 [vent.ItemStateChangedEvent] - PresenceText changed from ja to nein
2018-01-23 09:35:00.626 [ome.event.ItemCommandEvent] - Item 'TurnEverythingOff' received command ON
You mentioned that group items are not updated correctly after editing ANY items file? So what is the solution then? Restart of OH2 after editing items? Will there be a fix shortly for that behaviour?
To understand it correctly: does this issue only occur when I edit group items or items within that group or when I edit ANY item in an items file?
I ask that because I cannot remember that I have edited that group in question during the last months.
Can I avoid that behaviour when I switch off or on the group item manually directly after editing the items file?
For me this is not totally clear what really goes on. Sometimes all works fine at all, sometimes partly not, sometimes totally not.
I restart OH whenever I change the group item and not when I change items itself. If I think something is wrong, I restart it on any occation to be sure to have a correct reload of all definitions.
OK, good to know. I hope that behaviour will be fixed in near future.
Until then I will adopt your approach to restart OH2 when unexpected behaviour in relation with groups occurs.
If anyone of you finds a minimal reproducible example where something goes wrong, please make sure that you file an issue at https://github.com/eclipse/smarthome/issues so that it can be addressed - thanks!
