So I know we can set visibility on things inside the sitemap, but what about when items are part of a group? I have a couple dimmer switches where they have an on/off, and when on a slider for them shows. But, I would like to move these items into a group to reduce clutter, but still maintain this functionality. Is there some easy way to do this, or will I have to mess around with creating rules if an item is in a group?
When you add an Items to the sitemap from a Group using the Group element, you have no control over how the Items get displayed. It uses what ever the Item label and icon are set to and you cannot use visibility, MAPPINGS, color, or any other customization. If you have any customization of Items, you must add them to the sitemap individually.
You can put them into a subframe using the Frame element after a Text element:
Well that’s a bummer. Subframes are definitely nice, but after you get a ton of switches, it makes for a long list in Habdroid. But, its not the end of the world, as it still makes it nice and organized. Thanks.
I don’t think you quite understand how my example above works. It is essentially the same behavior as Group. You click on “Foo” and it opens a new frame with everything in the curly brackets. You are not forced to have EVERYTHING on one page.
My fault, I was thinking that was just the same thing as my Frame label=“Living Room Lights” {
If ‘Text item=“Foo” {’ works like a expand/collapse, that’d be perfect. Will try it out tonight after work.
