I’m beyond confused by this, I have removed my items file for the phones (IP and BT detection) and put the file back in place after confirming they are removed; but my group is reporting a status that is not ON. I have a fake phone item for overriding rules if someone is staying at my house that I don’t their phone setup in OpenHAB.
I caught this with my own phone the other night after seeing some oddness with a rule, so I don’t think its limited to a virtual device being a member.
Anyone else have a issue like this or have a suggestion of where I can go to resolve this?
Interesting find while troubleshooting this, I removed FakePhone from the group membership and the state of the group is working in an ON/OFF state. Still not sure what caused the issue as this wasn’t the behaviour when I first configured the items.
the group state “undefined” can happen, if you have not defined in which way the group state has to be calculated. If you have a group with switches (and only switches), you have to define it in a way like:
Group:Switch:OR(ON, OFF) group_movement
That means one Switch to “ON” is enough to switch the whole group to “ON” (OR). Did you define your group like that? if you just use
Excellent catch @spy0r! What still stumps me is that things did work as I would of kept working on it until it worked as an ON/OFF.
For future readers my second post about removing the FakePhone item membership did not change this behaviour in the long run; using the ‘Switch:OR(ON, OFF)’ resolved this issue.
