Acutally all of the items in the “sub groups” are switches, but want to switch in near future to contacts so i can forego a additional rule (one of the windows has another sensor wit the states open, tilted and closed).
The items all have a valid state an the group “Fenster Badezimmer” is counting right - but the one open window is not counted in the group above.
It’s simply the wrong naming then, as the channel is a string channel, not a contact channel.
Ahh…!
That detail wasn’t part of the question above… if you are using a group with other Group:Number Items in it (which have the contacts as members), then SUM is correct for this group.
