Hi All,
I have some LED RGBWC panel light with Tasmota firmware configured as group item:
Group:Switch:OR(ON,OFF) lp_ufficio_2 "Pannello Led ufficio 2" <light> (L71B_ufficio) ["Switch","Light"]
Switch lp_ufficio_2_p "Pannello Led Ufficio 2 Power" (lp_ufficio_2) {channel="mqtt:topic:lp_ufficio_2:lcu2_power"}
Dimmer lp_ufficio_2_d "Pannello Led Ufficio 2 Dimmer" (lp_ufficio_2) {channel="mqtt:topic:lp_ufficio_2:lcu2_dim"}
Dimmer lp_ufficio_2_ct "Pannello Led Ufficio 2 CT" (lp_ufficio_2) {channel="mqtt:topic:lp_ufficio_2:lcu2_ct"}
Color lp_ufficio_2_hsb "Pannello Led Ufficio 2 Colore" (lp_ufficio_2) {channel="mqtt:topic:lp_ufficio_2:lcu2_hsb"}
My problem is that state of group (ON or OFF) depend by only 2 items in group: Switch(the main power) and first dimmer (the dimmer). The second dimmer control CT white channel (cold or warm) and the color control RGB channel.
My problem is that I’m not able to find correct aggregation function to determinate correct group state.
If I use OR when lamp is OFF, by main power switch, but dimmer is not to 0% group state is ON. If I use AND when CT dimmer is set to 0% (cold white) group state is OFF also if lamp is actually ON.
There is a way to select only some items in order to determinate group status or, alternatively, a way to write custom aggregation function?
Thanks a lot in advance.
Gianluca
