Evening all,
I’ve set up one light (Study) and attached it to the group ‘Lights_Indoor’ which is attached to ‘Lights All’
The light switch and group switches control the LIFX bulb perfectly well, but the UI does not reflect the correct status.
For instance, when the ‘Study’ light is switched off using the ‘Study’ switch, there are no lights on in the group, but the icons remain in the ‘on’ state.
In the sample above, the ‘All Lights’ and ‘Indoor Lights’ switches should have gone ‘off’.
The same thing applies when switching the light back on from the item-level, it has no effect on the group switches.
That’s the ‘bottom up’ scenario. The ‘top down’ scenario works perfectly fine (Using the ‘All Lights’ switch correctly sets the ‘Indoor Lights’ and ‘Study Lights’ icons to on/off as appropriate.
The ‘Indoor Lights’ switch updated the ‘Study Light’ switch correctly, but has no affect on the ‘All Lights’ switch.
I’ve no idea about the nature of this issue
Here is my .items definition:
/* Lights */
Group:Switch:OR(ON, OFF) Lights_All "All Lights [%d]" <light>
Group:Switch:OR(ON, OFF) Lights_Indoor "Indoor Lights [%d]" <light> (Lights_All)
Group:Switch:OR(ON, OFF) Lights_Outdoor "Outdoor Lights [%d]" <light> (Lights_All)
Color Light_Study "Study Light [%d %%]" <light> (Lights_All, Lights_Indoor) { channel="lifx:colorlight:D073D51407BC:color" }
In the Basic UI, the two group switches update each other correctly but have no affect on the ‘Study’
Whether switching the groups on or off - not effect on the item ‘Study’:
In the Basic UI the ‘Study’ switch does control the two group switches, but after a spit second sets itself to the ‘off’ position and thereafter no longer works:
I’ve seen similar behaviour with my Domitech Z-Wave bulb and my Wemo lights so I don’t think its a binding issue
So it seems I’ve created some kind of disjoint in my setup. Can anyone advise?
