Hi All,
I’m having an issue with a rule that worked in OH2 but doesn’t seem to work well in OH 2.1. The behavior is really odd in that when the switch changes to OFF everything in the gLights group receives the command. Maybe my rule is screwed up? The second problem is that when the switch changes to ON it’s only supposed to send commands to 4 lights but you can see that it’s also sending the OFF command as well. Also noticed that it’s sending some commands more than once. I’ve been struggling to get this to work so any help or guidance is appreciated.
The Group
Group gLights
Example Item
Switch DR_Light "Dining Room Light" (gWakeup, gWatchTV, gBed, gLights ) ["Lighting"] {channel="zwave:device:51164f7d:node11:switch_binary"}
The Rule
rule "Presence if OFF"
when Item Presence changed
if (Presence.state==OFF)
gLights.members.forEach(s | if (s.state==ON) {
logInfo("Logging info", "Presence is off and turning off Lights")
gLights.sendCommand(OFF)
else
Entryway.sendCommand(ON)
DR_Light.sendCommand(ON)
Stairs1.sendCommand(ON)
LR_Lamp.sendCommand(ON)
The log entry
2017-08-03 11:39:45.614 [ItemCommandEvent ] - Item 'Presence' received command OFF
2017-08-03 11:39:45.614 [ItemStateChangedEvent ] - Presence changed from ON to OFF
2017-08-03 11:39:45.830 [ItemCommandEvent ] - Item 'gLights' received command OFF
2017-08-03 11:39:45.832 [ItemCommandEvent ] - Item 'DR_Light' received command OFF
2017-08-03 11:39:45.833 [ItemCommandEvent ] - Item 'gLights' received command OFF
2017-08-03 11:39:45.834 [ItemCommandEvent ] - Item 'Entryway' received command OFF
2017-08-03 11:39:45.835 [ItemCommandEvent ] - Item 'LR_Lamp' received command OFF
2017-08-03 11:39:45.845 [ItemCommandEvent ] - Item 'TV_Lightstrip' received command OFF
2017-08-03 11:39:45.857 [ItemCommandEvent ] - Item 'Kitchen' received command OFF
2017-08-03 11:39:45.858 [ItemCommandEvent ] - Item 'Porch' received command OFF
2017-08-03 11:39:45.859 [ItemCommandEvent ] - Item 'Deck' received command OFF
2017-08-03 11:39:45.859 [ItemCommandEvent ] - Item 'Patrick_Lights' received command OFF
2017-08-03 11:39:45.860 [ItemCommandEvent ] - Item 'Evie_Lights' received command OFF
2017-08-03 11:39:45.861 [ItemCommandEvent ] - Item 'Stairs1' received command OFF
2017-08-03 11:39:45.869 [ItemCommandEvent ] - Item 'Down_Bath' received command OFF
2017-08-03 11:39:45.870 [ItemCommandEvent ] - Item 'Downstairs_Light1' received command OFF
2017-08-03 11:39:45.882 [ItemCommandEvent ] - Item 'Garage' received command OFF
2017-08-03 11:39:45.883 [ItemStateChangedEvent ] - DR_Light changed from ON to OFF
2017-08-03 11:39:45.884 [ItemCommandEvent ] - Item 'DR_Light' received command OFF
2017-08-03 11:39:45.884 [ItemCommandEvent ] - Item 'Entryway' received command OFF
2017-08-03 11:39:45.885 [ItemCommandEvent ] - Item 'LR_Lamp' received command OFF
2017-08-03 11:39:45.896 [ItemCommandEvent ] - Item 'TV_Lightstrip' received command OFF
2017-08-03 11:39:45.908 [ItemCommandEvent ] - Item 'Kitchen' received command OFF
2017-08-03 11:39:45.909 [ItemCommandEvent ] - Item 'Porch' received command OFF
2017-08-03 11:39:45.910 [ItemCommandEvent ] - Item 'Deck' received command OFF
2017-08-03 11:39:45.910 [ItemCommandEvent ] - Item 'Patrick_Lights' received command OFF
2017-08-03 11:39:45.911 [ItemCommandEvent ] - Item 'Evie_Lights' received command OFF
2017-08-03 11:39:45.912 [ItemCommandEvent ] - Item 'Stairs1' received command OFF
2017-08-03 11:39:45.921 [ItemCommandEvent ] - Item 'Down_Bath' received command OFF
2017-08-03 11:39:45.921 [ItemCommandEvent ] - Item 'Downstairs_Light1' received command OFF
2017-08-03 11:39:45.934 [ItemCommandEvent ] - Item 'Garage' received command OFF
2017-08-03 11:39:45.949 [ItemStateChangedEvent ] - LR_Lamp changed from ON to OFF
2017-08-03 11:39:52.163 [ItemStateChangedEvent ] - LR_Lamp_Color changed from 0,0,100 to 0,0,0
2017-08-03 11:39:52.163 [ItemStateChangedEvent ] - LR_Lamp_Dimmer changed from 100 to 0
2017-08-03 11:40:23.068 [ItemCommandEvent ] - Item 'Presence' received command ON
2017-08-03 11:40:23.069 [ItemStateChangedEvent ] - Presence changed from OFF to ON
2017-08-03 11:40:23.111 [ItemCommandEvent ] - Item 'DR_Light' received command OFF
2017-08-03 11:40:23.111 [ItemCommandEvent ] - Item 'Entryway' received command ON
2017-08-03 11:40:23.112 [ItemCommandEvent ] - Item 'Entryway' received command OFF
2017-08-03 11:40:23.112 [ItemCommandEvent ] - Item 'DR_Light' received command ON
2017-08-03 11:40:23.113 [ItemCommandEvent ] - Item 'Stairs1' received command ON
2017-08-03 11:40:23.113 [ItemCommandEvent ] - Item 'LR_Lamp' received command OFF
2017-08-03 11:40:23.119 [ItemCommandEvent ] - Item 'LR_Lamp' received command ON
2017-08-03 11:40:23.131 [ItemCommandEvent ] - Item 'TV_Lightstrip' received command OFF
2017-08-03 11:40:23.148 [ItemStateChangedEvent ] - Entryway changed from OFF to ON
2017-08-03 11:40:23.148 [ItemStateChangedEvent ] - DR_Light changed from OFF to ON
2017-08-03 11:40:23.148 [ItemStateChangedEvent ] - LR_Lamp changed from OFF to ON
2017-08-03 11:40:23.150 [ItemStateChangedEvent ] - DR_Light changed from ON to OFF
2017-08-03 11:40:23.151 [ItemStateChangedEvent ] - Entryway changed from ON to OFF
2017-08-03 11:40:23.151 [ItemStateChangedEvent ] - Stairs1 changed from OFF to ON
2017-08-03 11:40:23.158 [ItemCommandEvent ] - Item 'Kitchen' received command OFF
2017-08-03 11:40:23.159 [ItemCommandEvent ] - Item 'Porch' received command OFF
2017-08-03 11:40:23.159 [ItemCommandEvent ] - Item 'Deck' received command OFF
2017-08-03 11:40:23.160 [ItemCommandEvent ] - Item 'Patrick_Lights' received command OFF
2017-08-03 11:40:23.161 [ItemCommandEvent ] - Item 'Evie_Lights' received command OFF
2017-08-03 11:40:23.162 [ItemCommandEvent ] - Item 'Stairs1' received command OFF
2017-08-03 11:40:23.162 [ItemStateChangedEvent ] - Stairs1 changed from ON to OFF
2017-08-03 11:40:23.172 [ItemCommandEvent ] - Item 'Down_Bath' received command OFF
2017-08-03 11:40:23.172 [ItemCommandEvent ] - Item 'Downstairs_Light1' received command OFF
2017-08-03 11:40:23.184 [ItemCommandEvent ] - Item 'Garage' received command OFF
2017-08-03 11:40:23.389 [ItemCommandEvent ] - Item 'Stairs2' received command OFF
2017-08-03 11:40:23.390 [ItemCommandEvent ] - Item 'Stairs2' received command OFF
