Groups in sitemap after OH 2.1 upgrade not working anymore
I had been using groups keyword without a group item to structure my sitemap. This approach does not work anymore with OH 2.1
If I use the following code in OH 2.1 i get the following error message
20:26:21.042 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘default.sitemap’ has errors, therefore ignoring it: [15,26]: rule ruleGroup failed predicate: {getUnorderedGroupHelper().canLeave(grammarAccess.getGroupAccess().getUnorderedGroup_1())}?
20:26:21.055 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘default.sitemap’ has errors, therefore ignoring it: [15,26]: rule ruleGroup failed predicate: {getUnorderedGroupHelper().canLeave(grammarAccess.getGroupAccess().getUnorderedGroup_1())}?
sitemap default label="Hauptmenue"
	Group label=Wohnzimmer {
		Text item=Esszimmer_Temperatur_Eingang
		Text item=Esszimmer_Temperatur_Terasse
		Slider item=L_Kueche switchSupport
		Slider item=L_Wohnzimmer switchSupport
		Slider item=L_Wand_Wohnzimmer switchSupport
		Slider item=L_Wand_Esszimmer switchSupport
		Switch item=L_Essen
	Group label=Treppenhaus {
		Switch item=Licht_Garderobe
		Switch item=L_Flur_EG
		Switch item=L_Flur_OG
See this topic:
https://community.openhab.org/t/latest-snapshot-doesnt-allow-group-without-item/21929
Using Text rather than Group should solve this problem.
Thanks! That solved the problem.
