All,
I am currently on the snapshot version of OpenHAB and I did an update last night and as soon as I restarted OpenHAB the standard Group functionality seems to have changed.
I have a rule the watches for a group to receive an update. In that group are a few switches and dimmers. If any of the switches or dimmers change or receive an update, the group was receiving an update, and that would trigger my rule. It was working fine until I updated last night. Now when one of the items changes or receives an update the group does not.
Did something change in that build? That’s a fairly big issue for me since I rely on that a good bit for my rules.
Info are missing:
OH2 Snapshot Build #
Items and Groups
Rules
Some logs
Without this info… no-one can provide substantial help
Btw: I am on the latest snapshot (932) I didn’t see any problems with Groups getting updates (I will check again)
Anyway, snapshots are unstable by definition
//Location Groups
Group gAll
Group gAllLights
Group gFirstFloor (gAll)
Group gSecondFloor (gAll)
Group gFrontPorch (gFirstFloor)
Group gEntry (gFirstFloor)
Group gLivingRoom (gFirstFloor)
Group gDiningArea (gFirstFloor)
Group gKitchen (gFirstFloor)
Group gHallway (gSecondFloor)
Group gMasterBedroom (gSecondFloor)
Group gUpstairsBathroom (gSecondFloor)
Dimmer LivingRoomCeilingLights "Living Room Ceiling Lights" <light> (gLivingRoom, gLights) ["Lighting"]
Dimmer EntryFanKeypad "Entry Fan Keypad" <light> (gLivingRoom, gCeilingLights)
Dimmer LivingRoomKeypad "Living Room Keypad" <light> (gLivingRoom, gCeilingLights)
Dimmer FrontLivingRoomFanLight "Front Living Room Fan Light" <light> (gLivingRoom, gCeilingLights)["Lighting"]
Number FrontLivingRoomFanSpeed "Front Living Room Fan Speed" <fan_ceiling> (gLivingRoom, gFans)
Dimmer RearLivingRoomFanLight "Rear Living Room Fan Light" <light> (gLivingRoom, gCeilingLights)["Lighting"]
Number RearLivingRoomFanSpeed "Rear Living Room Fan Speed" <fan_ceiling> (gLivingRoom, gFans)
Rule using these items that’s causing an issue:
rule SyncLivingRoom
Item gLivingRoom received update
logInfo("SyncLivingRoom", "gLivingRoom received update")
if (syncAllTimer == null)
syncAllTimer = createTimer(now.plusSeconds(2))[|
var itemsOn = gLivingRoom?.members.filter(items| items.state == ON || items.state > 0)
//logInfo("LivingRoomRules", "Items on in the Living Room: " + itemsOn.toString())
var numItemsOn = itemsOn.size
logInfo("LivingRoomRules", "Num Items On In Living Room: " + numItemsOn.toString())
if (numItemsOn > 0)
if (AllLivingRoom.state != ON)
AllLivingRoom.postUpdate(ON)
} else {
if (AllLivingRoom.state != OFF)
AllLivingRoom.postUpdate(OFF)
syncAllTimer = null
} else {
syncAllTimer.reschedule(now.plusSeconds(2))
There are no errors in the log. Actually there really is nothing in the log at all. The items update based on me changing the values or the bindings updating (they are on Insteon PLM) but the group just doesn’t update at all.
Maybe I should run update again to get to build 932, but if that doesn’t work I might role back. Just wanted to point it out so that if it is an issue it gets resolved if it’s not recognized yet.
Like I said, before I ran the update everything worked perfectly fine, even after rebooting the system a number of times. After the update, I rebooted about three times and that rule doesn’t work any more.
a group without a type or function can only be used for displaying purposes now, the state of the group does not change anymore.
Also see these not yet published doc changes:
I really am struggling to understand the reasoning behind that decision. I have a number of rules that rely on that behavior and it’s always been present and operated that way, so if that is the decision I have to say I really disagree with the decision to change it.
As far as I understand if you have a group with multiple types of items it can’t have a type or function. Am I understanding this correctly? And is there a way I can accomplish the same thing in a different way?
I can do that, the issue is I have multiple types of items in the same group and according to the docs that won’t work. I can play with it and see what happens.
It is just sooo frustrating when I get everything working and something like this changes and breaks all my code.
For every item type only the associated valid item states may be used in group definitions (switch only accepts on/off, contact only accepts open/closed, …).
From what I know ALL items accept NULL and UNDEF.
I’m using that with the expire binding for number items, after expiring the number item changes from a valid state to UNDEF through
Group:Number:OR(UNDEF,NULL) gCheckSensorStates "State [%s]"
and I am able to trigger rules on that group (changing from NULL to UNDEF) an easy way on UNDEF if they don’t get an update after some period of time (ESP8266 sensors sometimes hang …).
I don’t know if that would help for your setup.
Seems to me this should be announced as a breaking change.
While I don’t necessarily disagree with the change per se, it is a change that will break a lot of people’s rules (mine included). I think an announcement is warranted.
There’s another issue I seem to notice. When you nest groups, the documentation says that each item in the lowest level group should appear in or belong to the highest level group as well. But working with them that doesn’t seem to be the case.
That is a really good question. If that is the case I take back my original comment and do disagree with the change. This would be a step backwards for many of us.
Is anyone running with this code and can build up a test to see what works and what doesn’t?
This change invalidates a number of my Design Patterns and a good number of my running Rules.
I understand that breaking changes occur but to just drop this on the users unaware does not provide a good experience to the users.
I agree. This seems to be a major change without much user feedback or input from the community.
I did create a simple group for settings for the MapDB persistence service and have noticed it doesn’t seem to be saving my data on changes anymore. It might be that I have something set up incorrectly but here’s my setup.
This was working before the update and now is not. If this is due to the new group behavior I think we should consider whether this is a forward change or not since it will likely break a lot of already stable setups.
