Oh, I assumed that as it was Hierarchical as described in the docs, it would work top down.
Can it be changed with the aggregation function, or is that only for status?
It does.
Your set up has gofficelights at the top,
gall_lights is a member of gofficelights.
Send a command to gofficelights and it gets passed to any direct members, also to member gall_lights, and so to any of gall_lights members.
You probably meant to make it the other way round.
You tell your Items (including Group types) which groups to be members of.
(Not tell your Groups what they have for members)
Of course, as in the same syntax as adding an item in to a group, makes sense now.
Any chance of explaining that in the docs for others not to fall in the same trap?
There is a LOT to pick up when setting out with openHAB, but when you get the inevitable unexpected snags it’s worth reviewing the docs and examples (including in these forums) for misunderstandings.
I think for me, this Example needs to be expanded to look like this:
```csv
// Overarching group
Group House
// Location perspective
Group GroundFloor (House)
Group FirstFloor (House)
Group Livingroom (GroundFloor)
Group Kitchen (GroundFloor)
// Functional perspective
Group Sensors (House)
Group Temperatures (Sensors)
// Example Item
Number Livingroom_Temperature "Temperature [%.1f °C]" (Livingroom, Temperatures)
