Issue of the topic: Hello, i have made a group of Windowcontacts. All Items have a valid state and the state changes, but the groupstate ist always “NULL”.
So i made a Testgroup with one Contact and the groupstate is also “NULL”. So whats wrong?
Please post configurations (if applicable):
Items configuration related to the issue
’’‘Contact Tuer_EG_Eingang “Eingangstür” (EG_Flur, gFe, gTest) { knx=“1/5/81”}’’’
Thank you, i would try that for the group gFe.
I great a group with 1 item in it (gTest) and the state should be the same as the one Contact. Right? But i get the state NULL in Karaf for the group gTest and OPEN or CLOSED for the Contact
Thank you very much.
Now it works.
The solution are from both. I set the group aggregate function but nothing changed. Then I restart openhab and now it works. Thanks
