Correct, i will be rolling this out during the week, i’ll let everyone know when its finished.
well, since i needed to restart all services today anyways , i went ahead and rolled out our new container, so 3.0 should be fully supported !
Hi… thank you. Yes the admin page is now working after a clean install.
But Alexa discovery from the phone app is still giving HTTP protocol WWW-Authenticator error. Any suggestions to solve this. thnx
After testing, openhab’s first time setup happened faster with Zulu’s openJDK over Raspberry Pi OS’s openJDK. They’re both much faster than I remember on the Pi (used a 3B+), but it’ll still make a difference to use Zulu.
i use openhabian, how do i update from 2 to 3?
i disable ZRAM and run sudo apt install openhab commend then he wrote down
E: Unable to locate package openhab
you need to switch to snapshot in openhabian-config
(or edit the repo files)
EDIT: Beware that openHABian does not support OH3 yet.
how do i switch to snapshot in openhabian-config?
oh come on
menu 41
i get error: There was an error or interruption during the execution of: │
│ “40 | openHAB related”
echo 'deb https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable main' | sudo tee /etc/apt/sources.list.d/openhab2.list
Not sure where it goes wrong for me.
Tried it on a clone of my current production machine, and on a newly installed ubuntu 20.
Always getting “No apt package openhab”.
He proposes to use the snap installation way, but this results in ‘already installed’?
Any suggestion what I can try next?
Trust issue
apt update
Hit:1 http://be.archive.ubuntu.com/ubuntu focal InRelease
Get:2 http://be.archive.ubuntu.com/ubuntu focal-updates InRelease [111 kB]
Get:3 http://be.archive.ubuntu.com/ubuntu focal-backports InRelease [98.3 kB]
Get:4 http://be.archive.ubuntu.com/ubuntu focal-security InRelease [107 kB]
Ign:5 https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable InRelease
Err:6 https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable Release
Unknown date format Bad header data [IP: 35.231.52.82 443]
Reading package lists... Done
E: The repository 'https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Trusted issue bypass
I’ve changed this with option trusted=yes:
echo 'deb [trusted=yes] https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable main' | sudo tee /etc/apt/sources.list.d/openhab2.list
apt update
Ign:6 https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable Release
Ign:7 https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 Packages
Ign:8 https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main all Packages
Ign:9 https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main Translation-en
Ign:10 https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main all c-n-f Metadata
Ign:11 https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 c-n-f Metadata
Err:7 https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 Packages
404 Not Found [IP: 35.231.52.82 443]
Err:8 https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main all Packages
Fetched 317 kB in 7s (42.7 kB/s)
Building dependency tree
All packages are up to date.
W: Failed to fetch https://openhab.jfrog.io/openhab/openhab-linuxpkg/dists/unstable/main/binary-amd64/Packages 404 Not Found [IP: 35.231.52.82 443]
W: Failed to fetch https://openhab.jfrog.io/openhab/openhab-linuxpkg/dists/unstable/main/binary-all/Packages 404 Not Found [IP: 35.231.52.82 443]
W: Some index files failed to download. They have been ignored, or old ones used instead.
apt installation fails:
root@testVM:/home/tester# apt install openhab
No apt package "openhab", but there is a snap with that name.
Try "snap install openhab"
Snap installation fails
snap "openhab" is already installed, see 'snap help refresh'
Thanks for your feedback!
This is a known issue, please read Troubleshooting section in the first post.
I just tried the manually way, and this installed fine on a fresh Ubuntu 20.
Now trying to find the difference between 0H3 and OH2.5…
Tried the move to openHAB3 via the openhabian-config 41 (including the troubleshooting step), however it ended like:
mv: das Verschieben von '/var/lib/openhab/config/org/eclipse/smarthome/storage/json.config' nach '/var/lib/openhab/config/org/openhab/storage/json.config' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
dpkg: Fehler beim Bearbeiten des Paketes openhab (--configure):
»installiertes openhab-Skript des Paketes post-installation«-Unterprozess gab den Fehlerwert 1 zurück
Trigger für systemd (241-7~deb10u4+rpi1) werden verarbeitet ...
Fehler traten auf beim Bearbeiten von:
openhab
Updating FireMotD available updates count ...
E: Sub-process /usr/bin/dpkg returned an error code (1)
After manually creating the the folder /var/lib/openhab/config/org/openhab/storage
it did work!
openHABian is not yet ready for OH3 so you shouldn’t try to use it for this purpose.
Ups, in this case I missunderstood your conversation above with user “razserv2010”.
That was just how to switch to snapshots if you’re on openHABian because that’s what he asked.
Granted I should have made that clearer (and re-reading I think he made me victim to the XY problem).
Hi guys
first of all thanks for your great job.
After installing i have the following errors in log file
2020-10-04 07:09:58.039 [ERROR] [rnal.ChannelStateDescriptionProvider] - Dynamic state description matches original state description. DynamicStateDescriptionProvider implementations must never return the original state description. class org.openhab.binding.mqtt.generic.MqttChannelStateDescriptionProvider has to be fixed.
and the second one is related to influxdb persistence:
2020-10-04 07:11:15.382 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
org.influxdb.InfluxDBIOException: java.net.SocketTimeoutException: timeout
at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:831) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:460) ~[bundleFile:?]
at org.influxdb.impl.OneShotBatchWriter.write(OneShotBatchWriter.java:22) ~[bundleFile:?]
at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:340) [bundleFile:?]
at org.influxdb.impl.BatchProcessor$1.run(BatchProcessor.java:287) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: java.net.SocketTimeoutException: timeout
at okio.Okio$4.newTimeoutException(Okio.java:232) ~[bundleFile:?]
at okio.AsyncTimeout.exit(AsyncTimeout.java:286) ~[bundleFile:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:241) ~[bundleFile:?]
at okio.RealBufferedSource.indexOf(RealBufferedSource.java:358) ~[bundleFile:?]
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:230) ~[bundleFile:?]
at okhttp3.internal.http1.Http1ExchangeCodec.readHeaderLine(Http1ExchangeCodec.java:242) ~[bundleFile:?]
at okhttp3.internal.http1.Http1ExchangeCodec.readResponseHeaders(Http1ExchangeCodec.java:213) ~[bundleFile:?]
at okhttp3.internal.connection.Exchange.readResponseHeaders(Exchange.java:115) ~[bundleFile:?]
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:94) ~[bundleFile:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:142) ~[bundleFile:?]
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:43) ~[bundleFile:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:117) ~[bundleFile:?]
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:94) ~[bundleFile:?]
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93) ~[bundleFile:?]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:88) ~[bundleFile:?]
at org.influxdb.impl.BasicAuthInterceptor.intercept(BasicAuthInterceptor.java:22) ~[bundleFile:?]
at org.influxdb.impl.GzipRequestInterceptor.intercept(GzipRequestInterceptor.java:42) ~[bundleFile:?]
at okhttp3.logging.HttpLoggingInterceptor.intercept(HttpLoggingInterceptor.java:152) ~[bundleFile:?]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:229) ~[bundleFile:?]
at okhttp3.RealCall.execute(RealCall.java:81) ~[bundleFile:?]
at retrofit2.OkHttpCall.execute(OkHttpCall.java:188) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:819) ~[bundleFile:?]
... 10 more
Caused by: java.net.SocketException: Socket closed
at java.net.SocketInputStream.read(SocketInputStream.java:183) ~[?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:140) ~[?:?]
at okio.Okio$2.read(Okio.java:140) ~[bundleFile:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:237) ~[bundleFile:?]
... 10 more
... 10 more
... 10 more
How I can solve this issues ?
thanks in adavnce for your support.
Regards
Could you please open a new thread, ad this is not related to the installation prozess.
Sorry …done, if you want you can delete it to clean the thread.
I didn’t find a most suitable thread concerning version 3 and related errors so i posted here.
