Version 0.5.0
- Ignore Errors when SSE event is not a valid json
- Added possibility to load logging config first when using absolute paths
- Added log messages when loosing connection to OpenHAB
Version 0.5.0
Version 0.5.5
switchitem.on()
or switchitem.is_on()
if my_number_item < 5: ....
This looks like great work! Especially the possibility to use python libraries is great. Will definitely play with it soon. Is it also possible to use OH2 actions?
Unfortunately I have not found a way yet.
The easiest workaround is to use a proxy-item and trigger the action on an update of the item.
@Spaceman_Spiff I really like this! I’ve started using HabApp to convert some of my rules from DSL as I am somewhat familiar with python.
Is there any chance you can do some “bridging” between jython and HabApp to make actions work?
Hi @lfs_alp5, I am really glad you like it! I’ve tried to get information how to use actions, but so fare there is no possibility. I’ve also opened an issue on github.
A workaround is to define an item and then send commands to it.
e.g.
Dimmer MyOutput {channel = "zwave:device:controller:node7:switch_dimmer" }
or create a rule which listens to a proxy item and then executes the action.
Uploaded a new version
Version 0.6.8
from HABApp.openhab.items import SwitchItem
switch = SwitchItem.get_create_item('MySwitch')
switch.is_on()
This example shows how to create a rule with a function which will be called when any rule throws an error. The rule function then can push the error message to an openhab item or e.g. use Pushover to send the error message to the mobile device.
import HABApp
from HABApp.core import WrappedFunction
class NotifyOnError(HABApp.Rule):
def __init__(self):
super().__init__()
# so it get's unloaded propperly in case we make changes to this rule
self.register_on_unload(WrappedFunction.CLEAR_ERROR_CALLBACK)
# register function
WrappedFunction.REGISTER_ERROR_CALLBACK(self.on_error)
def on_error(self, error_message: str):
print(f'Message:\n{error_message}\n')
NotifyOnError()
# this is a faulty example. Do not create this part!
class FaultyRule(HABApp.Rule):
def __init__(self):
super().__init__()
self.run_soon(self.faulty_function)
def faulty_function(self):
1 / 0
FaultyRule()
will output:
Message:
Error in FaultyRule.faulty_function: division by zero
Traceback (most recent call last):
File "<string>", line 32, in faulty_function
ZeroDivisionError: division by zero
I seem to only get 0.6.6 via pip3, is there a delay before it’s “out” ?
Edit: and how do I loop a group?
Have you tried pip install --upgrade habapp
Thanks, my bad. I thought the install also upgraded if there was a newer version available
By the way, is there a way to loop item members in a group? Similar to DSL “MyGroup.members.forEach” ?
i have noticed this project only now,a nd i see you ahve been developing it for quite some time!
i’ll give it a try for sure!
I added a hint in the documentation on how to upgrade
Sure:
for item in self.openhab.get_item('MyGroup').members:
do_something()
However, since you can get items dynamically per name i almost exclusively use naming conventions to access my items.
Example:
from HABApp.openhab.items import SwitchItem, DimmerItem
class TestClass(Rule):
def __init__(self, part_name):
super().__init__()
self.switch = SwitchItem.get_create_item(f'{part_name}_Switch')
self.dimmer = DimmerItem.get_create_item(f'{part_name}_Dimmer')
TestClass('Kitchen')
TestClass('Office')
TestClass('...')
I’m having trouble getting that .members for loop going, it throws this:
[2019-08-04 17:20:45,948] [ HABApp.Rules] INFO | Added rule "MyOpenhabTestRule" from test.py
[2019-08-04 17:20:45,968] [ HABApp.Rules] ERROR | Could not load /etc/openhab2/rules/test.py: __init__() got an unexpected keyword argument 'stateDescription'!
[2019-08-04 17:20:45,969] [ HABApp.Rules] ERROR | File "/usr/local/lib/python3.7/site-packages/HABApp/openhab/oh_interface.py", line 52, in from_dict
[2019-08-04 17:20:45,969] [ HABApp.Rules] ERROR | data['members'][i] = cls.from_dict(item)
[2019-08-04 17:20:45,969] [ HABApp.Rules] ERROR | File "/usr/local/lib/python3.7/site-packages/HABApp/openhab/oh_interface.py", line 53, in from_dict
[2019-08-04 17:20:45,970] [ HABApp.Rules] ERROR | return cls(**data)
[2019-08-04 17:20:45,970] [ HABApp.Rules] ERROR | TypeError: __init__() got an unexpected keyword argument 'stateDescription'
The rule is as follows:
import HABApp
import logging
log = logging.getLogger('MyRule')
class MyOpenhabTestRule(HABApp.Rule):
def __init__(self):
super().__init__()
for item in self.openhab.get_item('gTemperatureInside').members:
log.debug(item.name)
MyOpenhabTestRule()
The group is defined like this:
Group gTemperatureInside (GAll)
Using OH 2.4.0 and HABApp 0.6.8
Ah, yes - this is a bug that is already fixed in the dev branch. I’ll upload a new version this evening.
Sorry for the inconvenience.
Version 0.6.9
Btw postprocessing error messages is really nice. If there is an error/exception in one of my rules it gets pushed directly to my mobile phone
I just tried to run the docker container on my RPi4 to test it out but it doesn’t look like the image is ARM-compatible. Any chance you can offer an image that will run on ARM?
What kind of problems are you experiencing?
I was under the impression that it should work on ARM, too.
Yea - I made the release but forgot to push it so pypi. Sorry again, will do it this evening.
pi@raspberrypi:~ $ sudo docker run spacemanspiff2007/habapp
standard_init_linux.go:211: exec user process caused "exec format error"
I’ve previously seen this error when the image isn’t ARM compatible.
