It seems I already did some work on it.
It has been and always will be ongoing and I am happy for everyone who is willing to help.
Ah, excellent.
Yes, My guess; this is where the real work have to be done.
Should actually be pretty easy - just take the configuration of the thing, add the item name (after it was created) to linkedItems
and post it to the thing/config
endpoint again.
This would actually make a pretty nice feature:
AutoLink, where the thing-type gets specified and the items get created and linked automatically after the specified schema.
Regarding the auto-link feature from a schema: this is basically what OpenHAB *.items files are in my opinion. That works great, but is somehow tedious. But creating those automatically without deeper knowledge of the device is hard I think.
For example: the automatically created item in OpenHAB for the DecalcificationTime had the Time type in OpenHAB, but it is just the number of minutes since midnight which fails parsing for a time of course.
I looked at the Api documentation and there is a links/ endpoint that allows working with links directly based on itemname and channelUID, both available already. Simple CRUD methods could be enough to be able to work with it in conjunction with get_thing.
Yes, and probably varies on different use cases too.
In my case I need about 20 magnet sensors just for my livingroom heatpump.
Hi Guys I managed to send a command via habapp and turn on a switch the following both worked for me as intended:
self.oh.send_command("testsw1","ON")
myswitch = SwitchItem.get_item("testsw1")
myswitch.on()
In the Habapp Log I see the following errors even though everything works as intended:
[2020-04-26 09:22:01,915] [ HABApp] ERROR | Error <class 'NoneType'> in on_sse_event:
[2020-04-26 09:22:01,915] [ HABApp] ERROR | Traceback (most recent call last):
[2020-04-26 09:22:01,915] [ HABApp] ERROR | File "/Users/thomasbecker/PycharmProjects/PycharmProjects/Privat/HabApp/lib/python3.7/site-packages/HABApp/openhab/oh_connection.py", line 117, in on_sse_event
[2020-04-26 09:22:01,915] [ HABApp] ERROR | event = get_event(event_dict)
[2020-04-26 09:22:01,916] [ HABApp] ERROR | File "/Users/thomasbecker/PycharmProjects/PycharmProjects/Privat/HabApp/lib/python3.7/site-packages/HABApp/openhab/map_events.py", line 38, in get_event
[2020-04-26 09:22:01,916] [ HABApp] ERROR | return __event_lookup[event_type].from_dict(topic, payload)
[2020-04-26 09:22:01,916] [ HABApp] ERROR | File "/Users/thomasbecker/PycharmProjects/PycharmProjects/Privat/HabApp/lib/python3.7/site-packages/HABApp/openhab/events/item_events.py", line 19, in from_dict
[2020-04-26 09:22:01,916] [ HABApp] ERROR | return cls(topic[16:-6], map_openhab_values(payload['type'], payload['value']))
[2020-04-26 09:22:01,916] [ HABApp] ERROR | File "/Users/thomasbecker/PycharmProjects/PycharmProjects/Privat/HabApp/lib/python3.7/site-packages/HABApp/openhab/map_values.py", line 9, in map_openhab_values
[2020-04-26 09:22:01,916] [ HABApp] ERROR | assert isinstance(openhab_value, str), type(openhab_value)
[2020-04-26 09:22:01,916] [ HABApp] ERROR | AssertionError: <class 'NoneType'>
[2020-04-26 09:22:01,942] [ HABApp] ERROR | Error <class 'NoneType'> in on_sse_event:
[2020-04-26 09:22:01,942] [ HABApp] ERROR | Traceback (most recent call last):
[2020-04-26 09:22:01,942] [ HABApp] ERROR | File "/Users/thomasbecker/PycharmProjects/PycharmProjects/Privat/HabApp/lib/python3.7/site-packages/HABApp/openhab/oh_connection.py", line 117, in on_sse_event
[2020-04-26 09:22:01,942] [ HABApp] ERROR | event = get_event(event_dict)
[2020-04-26 09:22:01,942] [ HABApp] ERROR | File "/Users/thomasbecker/PycharmProjects/PycharmProjects/Privat/HabApp/lib/python3.7/site-packages/HABApp/openhab/map_events.py", line 38, in get_event
[2020-04-26 09:22:01,942] [ HABApp] ERROR | return __event_lookup[event_type].from_dict(topic, payload)
[2020-04-26 09:22:01,942] [ HABApp] ERROR | File "/Users/thomasbecker/PycharmProjects/PycharmProjects/Privat/HabApp/lib/python3.7/site-packages/HABApp/openhab/events/item_events.py", line 19, in from_dict
[2020-04-26 09:22:01,942] [ HABApp] ERROR | return cls(topic[16:-6], map_openhab_values(payload['type'], payload['value']))
[2020-04-26 09:22:01,942] [ HABApp] ERROR | File "/Users/thomasbecker/PycharmProjects/PycharmProjects/Privat/HabApp/lib/python3.7/site-packages/HABApp/openhab/map_values.py", line 9, in map_openhab_values
[2020-04-26 09:22:01,942] [ HABApp] ERROR | assert isinstance(openhab_value, str), type(openhab_value)
[2020-04-26 09:22:01,943] [ HABApp] ERROR | AssertionError: <class 'NoneType'>
How can i correct those?
Hm, strange. Can you download the current Dev Branch from github and try it again?
You can just copy all files from the HABApp directory to
will do tomorrow
Thats weird i know get this:
[2020-04-28 11:58:08,544] [HABApp.openhab.Connection] INFO | Updated 88 Things
[2020-04-28 11:58:11,942] [ HABApp.Rules] ERROR | Error "name 'self' is not defined" in load:
[2020-04-28 11:58:11,942] [ HABApp.Rules] ERROR | Could not load /Users/thomasbecker/PycharmProjects/PycharmProjects/Privat/HABApp/rules/Motion.py!
[2020-04-28 11:58:11,942] [ HABApp.Rules] ERROR | File /Library/Developer/CommandLineTools/Library/Frameworks/Python3.framework/Versions/3.7/lib/python3.7/runpy.py, line 263, in run_path
[2020-04-28 11:58:11,942] [ HABApp.Rules] ERROR | 239 def run_path(path_name, init_globals=None, run_name=None):
[2020-04-28 11:58:11,942] [ HABApp.Rules] ERROR | (...)
[2020-04-28 11:58:11,942] [ HABApp.Rules] ERROR | 259 # Not a valid sys.path entry, so run the code directly
[2020-04-28 11:58:11,942] [ HABApp.Rules] ERROR | 260 # execfile() doesn't help as we want to allow compiled files
[2020-04-28 11:58:11,943] [ HABApp.Rules] ERROR | 261 code, fname = _get_code_from_file(run_name, path_name)
[2020-04-28 11:58:11,943] [ HABApp.Rules] ERROR | 262 return _run_module_code(code, init_globals, run_name,
[2020-04-28 11:58:11,943] [ HABApp.Rules] ERROR | --> 263 pkg_name=pkg_name, script_name=fname)
[2020-04-28 11:58:11,943] [ HABApp.Rules] ERROR | 264 else:
[2020-04-28 11:58:11,943] [ HABApp.Rules] ERROR | ..................................................
[2020-04-28 11:58:11,943] [ HABApp.Rules] ERROR | path_name = '/Users/thomasbecker/PycharmProjects/PycharmProjects/Privat/
[2020-04-28 11:58:11,943] [ HABApp.Rules] ERROR | HABApp/rules/Motion.py'
[2020-04-28 11:58:11,943] [ HABApp.Rules] ERROR | init_globals = {'__HABAPP__RUNTIME__': <HABApp.runtime.runtime.Runtime obje
[2020-04-28 11:58:11,943] [ HABApp.Rules] ERROR | ct at 0x106c96e10>,
[2020-04-28 11:58:11,943] [ HABApp.Rules] ERROR | '__HABAPP__RULE_FILE__': <HABApp.rule_manager.rule_file.Rul
[2020-04-28 11:58:11,943] [ HABApp.Rules] ERROR | eFile object at 0x108ddea20>,
[2020-04-28 11:58:11,943] [ HABApp.Rules] ERROR | '__HABAPP__RULES': []}
[2020-04-28 11:58:11,943] [ HABApp.Rules] ERROR | run_name = '/Users/thomasbecker/PycharmProjects/PycharmProjects/Privat/
and so on. I didnât change the code at all:
from HABApp.core.events import ValueUpdateEvent, ValueChangeEvent
from HABApp.openhab.events import ItemStateEvent, ItemCommandEvent, ItemStateChangedEvent
from HABApp.openhab.items import NumberItem
from HABApp.openhab.items import SwitchItem
class Motion(HABApp.Rule):
def __init__(self):
super().__init__()
# Trigger on item updates
self.listen_event('HueMotionEssbePresence', self.item_state_update, ValueUpdateEvent)
def item_state_update(self, event):
assert isinstance(event, ValueUpdateEvent)
print(f'{event}')
myswitch.on()
Motion()
Hi @Tomibeck.
I copy-pasted your code and also received an error. Try adding import HABApp
at the top.
Yes, its either
import HABApp
or
from HABApp import Rule
class Motion(Rule):
Edit:
Protip
You should always create the items in __init__
and use them later in the rule.
This helps catching typos on file load and is generally less error prone:
class Motion(Rule):
def __init__(self):
super().__init__()
self.presence = NumberItem.get_item('HueMotionEssbePresence')
self.presence.listen_event(self.item_state_update, ValueUpdateEvent)
self.myswitch = SwitchItem.get_item("testsw1")
def item_state_update(self, event: ValueUpdateEvent):
if self.presence:
self.myswitch.on()
else:
self.myswitch.off()
Motion()
Thats good stuff thanks. I will try this later. So its either creating all the Items in super init or directly interacting with the openhab itme for example via
self.oh.send_command(âtestsw1â,âONâ)
I am not shure if this is out of place, but here goes:
I started to play around with the @noidea github rep,
and I could not find out how to extract all the Things.
I ended up copy/edit get_items into a get_things function.
Is there a list that includes all Things somewhere else i habapp?
I do not know the direction @Spaceman_Spiff intend to take HABApp in the future but with the Things I can write some cool rules just by looping thru the list:
A very generic battery status check
Get all offline Things
Get signal strength, neighbour and routing for Zigbee devices
The things and their status are already included in HABApp and loaded on connect.
import HABApp
for item in HABApp.core.Items.get_all_items():
if isinstance(item, HABApp.openhab.items.Thing):
print(f'{item.name}: {item.status}')
If you want further information like configuration you have to query openhab.
Iâll add a get_thing
function in the dev branch
Edit:
Can you show an example how you would do a battery check?
Thank you! I look into that.
Hehe, no, on second tought, it would be better to just loop thru the Items
On second thought on the second thought, I think I got it right the first time. One would need to see the âbattery-levelâ part of the channel.
zwave:device:89aa3c34:node22:battery-level
hue:0106:1:SoveromNord_Lum:battery_level
zigbee:philips_sml001:01381602:0017880106f7e084:battery_level
And probably use the linked Item (if any) to read the battery level.
Some devices report a battery voltage. One could take some guesses about what a good voltage is.
Also, some devices have a battery alarm channel.
Devices can have channels for all 3 methods.
Im still reading into all the new-fangled things in Python, as I have not used it in 15 years or so.
If you have named your items properly itâs way easier to just iterate over all items and see if the end with âbatteryâ (or however you have named them). I havenât seen voltage yet, only percent.
Version 0.13.0
value
propertyval = NumberItem('item1') + NumberItem('item2')
val = NumberItem('item1').value + NumberItem('item2').value
Bugfix:
I really like the new SwitchItemValueMode
With just one line of code I can disable all lower modes from the MultiModeItem
from an openhab SwitchItem
I use it to have the possibility disable my complex shutter rules and only allow manual movement of the shades. Example usage:
# use invert_switch to switch off, the next line does all the magic
automatic_off = SwitchItemValueMode('AutomaticOff', switch, invert_switch=True)
manual_mode = ValueMode('Manual')
item = MultiModeItem.get_create_item('MultiModeTestItem')
item.add_mode(100, automatic_off)
item.add_mode(101, manual_mode)
Iâm trying to install habapp but when I run the command âpython3 -m pip install habappâ I have these errors:
ERROR: Could not find a version that satisfies the requirement astral==2.1
ERROR: Could not find a version that satisfies the requirement pydantic==1.5.1
What am I doing wrong?
Strange, I sucessfully installed it just yesterday.
Does the machine have proper internet access and can you install any package from pypi?
