I have somehow managed to fail the basic example in the HABApp docs. When I create the test.py file I get the following error in the logs:
[2021-05-05 09:39:52,000] [ HABApp.Rules] ERROR | Error "'MyFirstRule' object has no attribute 'run'" in load:
[2021-05-05 09:39:52,000] [ HABApp.Rules] ERROR | Could not load /etc/openhab2/habapp/rules/test.py!
[2021-05-05 09:39:52,001] [ HABApp.Rules] ERROR | File "/home/dan/.local/lib/python3.6/site-packages/HABApp/rule_manager/rule_file.py", line 79, in load
[2021-05-05 09:39:52,001] [ HABApp.Rules] ERROR | self.create_rules(created_rules)
[2021-05-05 09:39:52,001] [ HABApp.Rules] ERROR | File "/home/dan/.local/lib/python3.6/site-packages/HABApp/rule_manager/rule_file.py", line 68, in create_rules
[2021-05-05 09:39:52,001] [ HABApp.Rules] ERROR | '__HABAPP__RULES': created_rules,
[2021-05-05 09:39:52,001] [ HABApp.Rules] ERROR | File "/usr/lib/python3.6/runpy.py", line 263, in run_path
[2021-05-05 09:39:52,001] [ HABApp.Rules] ERROR | pkg_name=pkg_name, script_name=fname)
[2021-05-05 09:39:52,002] [ HABApp.Rules] ERROR | File "/usr/lib/python3.6/runpy.py", line 96, in _run_module_code
[2021-05-05 09:39:52,002] [ HABApp.Rules] ERROR | mod_name, mod_spec, pkg_name, script_name)
[2021-05-05 09:39:52,002] [ HABApp.Rules] ERROR | File "/usr/lib/python3.6/runpy.py", line 85, in _run_code
[2021-05-05 09:39:52,002] [ HABApp.Rules] ERROR | exec(code, run_globals)
[2021-05-05 09:39:52,002] [ HABApp.Rules] ERROR | File "/etc/openhab2/habapp/rules/test.py", line 16, in test.py
[2021-05-05 09:39:52,003] [ HABApp.Rules] ERROR | 12 def say_something(self):
[2021-05-05 09:39:52,003] [ HABApp.Rules] ERROR | 13 print('That was easy!')
[2021-05-05 09:39:52,003] [ HABApp.Rules] ERROR | 14
[2021-05-05 09:39:52,003] [ HABApp.Rules] ERROR | 15 # Rules
[2021-05-05 09:39:52,003] [ HABApp.Rules] ERROR | --> 16 MyFirstRule()
[2021-05-05 09:39:52,003] [ HABApp.Rules] ERROR | ..................................................
[2021-05-05 09:39:52,003] [ HABApp.Rules] ERROR | MyFirstRule = <class '/etc/openhab2/habapp/rules/test.py.MyFirstRule'>
[2021-05-05 09:39:52,004] [ HABApp.Rules] ERROR | ..................................................
[2021-05-05 09:39:52,004] [ HABApp.Rules] ERROR | File "/etc/openhab2/habapp/rules/test.py", line 10, in __init__
[2021-05-05 09:39:52,004] [ HABApp.Rules] ERROR | 5 def __init__(self):
[2021-05-05 09:39:52,004] [ HABApp.Rules] ERROR | 6 super().__init__()
[2021-05-05 09:39:52,004] [ HABApp.Rules] ERROR | 7
[2021-05-05 09:39:52,004] [ HABApp.Rules] ERROR | 8 # Use run.at to schedule things directly after instantiation,
[2021-05-05 09:39:52,004] [ HABApp.Rules] ERROR | 9 # don't do blocking things in __init__
[2021-05-05 09:39:52,004] [ HABApp.Rules] ERROR | --> 10 self.run.soon(self.say_something)
[2021-05-05 09:39:52,005] [ HABApp.Rules] ERROR | ..................................................
[2021-05-05 09:39:52,005] [ HABApp.Rules] ERROR | self = </etc/openhab2/habapp/rules/test.py.MyFirstRule object at 0x7f0c14044a90>
[2021-05-05 09:39:52,005] [ HABApp.Rules] ERROR | self.run.soon = # AttributeError
[2021-05-05 09:39:52,005] [ HABApp.Rules] ERROR | self.say_something = <method 'MyFirstRule.say_something' of </etc/openhab2/habapp/rules/test.py.MyFirstRule object at 0x7f0c14044a90> test.py:12>
[2021-05-05 09:39:52,005] [ HABApp.Rules] ERROR | AttributeError: 'MyFirstRule' object has no attribute 'run'
[2021-05-05 09:39:52,005] [ HABApp.Rules] WARNING | Failed to load /etc/openhab2/habapp/rules/test.py!
Would be fantastic if anyone can see what I’m doing wrong…
