The reason why there is a delay between both timestamps is, because I triggered both test programs manually.
The values will change rarely (num_Heating_Maintenance_Pellets
, manually triggered, once in two years; num_Softener_WaterCounter_PreviousDay
, once a day, close to midnight)
The last start of the system was a couple of days ago, so a restore via mapdb shouldn’t take place.
[2022-10-29 17:45:39,900] [ HABApp.EventBus] INFO | num_Server_Storage_AvailablePercent: <ItemStateEvent name: num_Server_Storage_AvailablePercent, value: 93.1>
[2022-10-29 17:45:40,811] [ HABApp.EventBus] INFO | swi_System_HABAppTest: <ItemCommandEvent name: swi_System_HABAppTest, value: ON>
[2022-10-29 17:45:40,823] [ HABApp.EventBus] INFO | swi_System_HABAppTest: <ItemStateEvent name: swi_System_HABAppTest, value: ON>
[2022-10-29 17:45:40,832] [ HABApp.EventBus] INFO | swi_System_HABAppTest: <ItemStateChangedEvent name: swi_System_HABAppTest, value: ON, old_value: OFF>
[2022-10-29 17:45:40,847] [ HABApp.EventBus] INFO | swi_System_HABAppTest: <ItemCommandEvent name: swi_System_HABAppTest, value: OFF>
[2022-10-29 17:45:40,850] [ HABApp.EventBus] INFO | swi_System_HABAppTest: <ItemStateEvent name: swi_System_HABAppTest, value: OFF>
[2022-10-29 17:45:40,853] [ HABApp.EventBus] INFO | swi_System_HABAppTest: <ItemStateChangedEvent name: swi_System_HABAppTest, value: OFF, old_value: ON>
[2022-10-29 17:45:41,322] [ HABApp.EventBus] INFO | swi_System_Test: <ItemStateEvent name: swi_System_Test, value: OFF>
[2022-10-29 17:45:41,326] [ HABApp.EventBus] INFO | swi_System_Test: <ItemStateChangedEvent name: swi_System_Test, value: OFF, old_value: ON>
[2022-10-29 17:45:42,044] [ HABApp.EventBus] INFO | swi_Network_ShellyEM2_Online: <ItemStateEvent name: swi_Network_ShellyEM2_Online, value: OFF>
[2022-10-29 17:45:42,635] [ HABApp.EventBus] INFO | dtm_Astro_Rise_Start: <ItemStateEvent name: dtm_Astro_Rise_Start, value: 2022-10-29 07:58:00>
[2022-10-29 17:45:42,639] [ HABApp.EventBus] INFO | dtm_Astro_Rise_End: <ItemStateEvent name: dtm_Astro_Rise_End, value: 2022-10-29 08:01:00>
[2022-10-29 17:45:42,643] [ HABApp.EventBus] INFO | dtm_Astro_Set_Start: <ItemStateEvent name: dtm_Astro_Set_Start, value: 2022-10-29 18:02:00>
[2022-10-29 17:45:42,646] [ HABApp.EventBus] INFO | dtm_Astro_Set_End: <ItemStateEvent name: dtm_Astro_Set_End, value: 2022-10-29 18:05:00>
[2022-10-29 17:45:42,649] [ HABApp.EventBus] INFO | dtm_Astro_CivilDawn_Start: <ItemStateEvent name: dtm_Astro_CivilDawn_Start, value: 2022-10-29 07:26:00>
[2022-10-29 17:45:42,653] [ HABApp.EventBus] INFO | dtm_Astro_CivilDawn_End: <ItemStateEvent name: dtm_Astro_CivilDawn_End, value: 2022-10-29 07:58:00>
[2022-10-29 17:45:42,654] [ HABApp.EventBus] INFO | dtm_Astro_CivilDusk_Start: <ItemStateEvent name: dtm_Astro_CivilDusk_Start, value: 2022-10-29 18:05:00>
[2022-10-29 17:45:42,657] [ HABApp.EventBus] INFO | dtm_Astro_CivilDusk_End: <ItemStateEvent name: dtm_Astro_CivilDusk_End, value: 2022-10-29 18:38:00>
[2022-10-29 17:45:42,667] [ HABApp.EventBus] INFO | num_Astro_SunPos_Horizontal: <ItemStateEvent name: num_Astro_SunPos_Horizontal, value: 247.08113019600614 °>
[2022-10-29 17:45:42,676] [ HABApp.EventBus] INFO | num_Astro_SunPos_Vertical: <ItemStateEvent name: num_Astro_SunPos_Vertical, value: 2.0852916255597878 °>
[2022-10-29 17:45:42,679] [ HABApp.EventBus] INFO | num_Astro_SunPos_Horizontal: <ItemStateChangedEvent name: num_Astro_SunPos_Horizontal, value: 247.08113019600614 °, old_value: 246.13722652498802 °>
[2022-10-29 17:45:42,682] [ HABApp.EventBus] INFO | num_Astro_SunPos_Vertical: <ItemStateChangedEvent name: num_Astro_SunPos_Vertical, value: 2.0852916255597878 °, old_value: 2.8525500106635806 °>
[2022-10-29 17:45:43,333] [ HABApp.EventBus] INFO | dtm_Astro_MoonRise_Start: <ItemStateEvent name: dtm_Astro_MoonRise_Start, value: 2022-10-29 13:02:00>
[2022-10-29 17:45:43,343] [ HABApp.EventBus] INFO | dtm_Astro_MoonSet_End: <ItemStateEvent name: dtm_Astro_MoonSet_End, value: 2022-10-29 20:37:00>
[2022-10-29 17:45:43,349] [ HABApp.EventBus] INFO | num_Astro_MoonPhase_Illum: <ItemStateEvent name: num_Astro_MoonPhase_Illum, value: 21.5643322497035 %>
[2022-10-29 17:45:43,351] [ HABApp.EventBus] INFO | str_Astro_MoonPhase_Name: <ItemStateEvent name: str_Astro_MoonPhase_Name, value: WAXING_CRESCENT>
[2022-10-29 17:45:43,352] [ HABApp.EventBus] INFO | num_Astro_MoonPhase_Illum: <ItemStateChangedEvent name: num_Astro_MoonPhase_Illum, value: 21.5643322497035 %, old_value: 21.531001260939693 %>
[2022-10-29 17:45:44,444] [ HABApp.EventBus] INFO | HABApp_Ping: <ItemStateEvent name: HABApp_Ping, value: 14.5>
[2022-10-29 17:45:44,448] [ HABApp.EventBus] INFO | HABApp_Ping: <ItemStateChangedEvent name: HABApp_Ping, value: 14.5, old_value: 22.5>
[2022-10-29 17:45:46,431] [ HABApp.EventBus] INFO | dtm_Weather_Time: <ItemStateEvent name: dtm_Weather_Time, value: 2022-10-29 19:00:00>
