i have problem with Habmin2 for openhab 2 on raspbian. When i try to use UI Habmin, it shows only “loading…”, and then nothing. Maybe it is something worg with intalling openhab2 on Raspian. Can you give me some tips.
On this Site: https://github.com/openhab/org.openhab.ui.habmin#openhab-2 i can not understand what should i do, there is no tutorial for installing Habmin2.
I have same problem that quangtuyentran had/have.
I have used openHAB 1.8 version, but now I installed version 2.0 with Habmin.
Allready tried several uninstall and install, but still same problem!
I am using Raspberry Pi 3 with Raspberry Jessie.
Do I have to do clean install for everything or what can I check for troubleshooting?
