i have a strange issue with HABmin and 2 of my zwave thermostats (MH8-FC)
recently i added 2 of them into my zwave network and they are working as expected however in the Z-Wave Network Viewer in HABmin they’re showing as not having any connection to the controller or other device
im running currently opanHAB 2.2 Build 985 (openHABian)
node 13,20 and 21 are the same type of device. 20 and 21 are the recent added thermostats.
confirmed. I see detached nodes in my map while using the “regular” Z-Wave binding while in the refactored version, the map looks much better (with links to/from all devices)
ok i will give the refactored version a try. however the MH8 thermostats are not battery driven devices. they are actually used to control my AC and running on 220V
I still have three devices without links in the refactored binding, but I think I had more of them in the regular binding, so the refactored is better, if not perfect.
