I’ve recently received an Aeotec Multisensor 6. At first the temperature calibration seemed out so I adjusted the calibration parameter using HABmin2 and things seemed OK. Now the readings seem to have settled but now the readings are out by roughly the calibration change I entered so I need to change the calibration parameter back to default/0.
However using HABmin2 I’m unable to reset this parameter. Having checked the logs I can see this happens when I enter an offset successfully:
2015-12-30 00:50:38.668 [DEBUG] [.z.i.config.ZWaveConfiguration:1091]- doSet domain 'nodes/node4/parameters/configuration201' to '-35'
2015-12-30 00:50:38.922 [DEBUG] [.z.i.config.ZWaveConfiguration:1177]- Set parameter index '201' to '-35'
2015-12-30 00:50:38.925 [DEBUG] [ZWaveConfigurationCommandClass:188 ]- NODE 4: Creating new message for application command CONFIGURATIONCMD_SET
2015-12-30 00:50:38.927 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ]- NODE 4: Creating empty message of class = SendData (0x13), type = Request (0x00)
2015-12-30 00:50:38.929 [DEBUG] [b.z.i.protocol.ZWaveController:938 ]- Callback ID = 23
2015-12-30 00:50:38.930 [DEBUG] [b.z.i.protocol.ZWaveController:620 ]- Enqueueing message. Queue length = 1
2015-12-30 00:50:38.930 [DEBUG] [WaveController$ZWaveSendThread:1211]- Took message from queue for sending. Queue length = 0
2015-12-30 00:50:38.931 [DEBUG] [ZWaveConfigurationCommandClass:160 ]- NODE 4: Creating new message for application command CONFIGURATIONCMD_GET
2015-12-30 00:50:38.933 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 0C 00 13 04 05 70 04 C9 01 DD 25 17 B2
2015-12-30 00:50:38.933 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ]- NODE 4: Creating empty message of class = SendData (0x13), type = Request (0x00)
2015-12-30 00:50:38.935 [DEBUG] [WaveController$ZWaveSendThread:1268]- NODE 4: Sending REQUEST Message = 01 0C 00 13 04 05 70 04 C9 01 DD 25 17 B2
2015-12-30 00:50:38.936 [DEBUG] [b.z.i.protocol.ZWaveController:938 ]- Callback ID = 24
2015-12-30 00:50:38.938 [DEBUG] [b.z.i.protocol.ZWaveController:620 ]- Enqueueing message. Queue length = 1
2015-12-30 00:50:38.945 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 04 01 13 01 E8
2015-12-30 00:50:38.947 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=1
2015-12-30 00:50:38.947 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2015-12-30 00:50:38.948 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 04 01 13 01 E8
2015-12-30 00:50:38.949 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 04 01 13 01 E8
2015-12-30 00:50:38.950 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = SendData (0x13), type = Response (0x01), payload = 01
2015-12-30 00:50:38.951 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ]- NODE 4: Sent Data successfully placed on stack.
2015-12-30 00:50:38.962 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 07 00 13 17 00 00 02 FE
2015-12-30 00:50:38.967 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=1
2015-12-30 00:50:38.967 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2015-12-30 00:50:38.969 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 09 00 13 17 00 00 02 00 00 F0
2015-12-30 00:50:38.970 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 09 00 13 17 00 00 02 00 00 F0
2015-12-30 00:50:38.971 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = SendData (0x13), type = Request (0x00), payload = 17 00 00 02
2015-12-30 00:50:38.972 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ]- NODE 4: SendData Request. CallBack ID = 23, Status = Transmission complete and ACK received(0)
2015-12-30 00:50:38.973 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ]- Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 04 05 70 04 C9 01 DD
2015-12-30 00:50:38.974 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ]- Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 17 00 00 02
2015-12-30 00:50:38.975 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ]- Checking transaction complete: class=SendData, expected=SendData, cancelled=false
2015-12-30 00:50:38.976 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:68 ]- transaction complete!
2015-12-30 00:50:38.976 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveTransactionCompletedEvent
2015-12-30 00:50:38.977 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-12-30 00:50:38.977 [DEBUG] [WaveController$ZWaveSendThread:1327]- NODE 4: Response processed after 41ms/3389ms.
2015-12-30 00:50:38.978 [DEBUG] [WaveController$ZWaveSendThread:1211]- Took message from queue for sending. Queue length = 0
2015-12-30 00:50:38.979 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 0A 00 13 04 03 70 05 C9 25 18 60
2015-12-30 00:50:38.981 [DEBUG] [WaveController$ZWaveSendThread:1268]- NODE 4: Sending REQUEST Message = 01 0A 00 13 04 03 70 05 C9 25 18 60
2015-12-30 00:50:38.990 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 04 01 13 01 E8
2015-12-30 00:50:38.992 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=1
2015-12-30 00:50:38.992 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2015-12-30 00:50:38.994 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 04 01 13 01 E8
2015-12-30 00:50:38.994 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 04 01 13 01 E8
2015-12-30 00:50:38.995 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = SendData (0x13), type = Response (0x01), payload = 01
2015-12-30 00:50:38.996 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ]- NODE 4: Sent Data successfully placed on stack.
2015-12-30 00:50:39.007 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 07 00 13 18 00 00 02 F1
2015-12-30 00:50:39.009 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=1
2015-12-30 00:50:39.009 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2015-12-30 00:50:39.010 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 09 00 13 18 00 00 02 00 00 FF
2015-12-30 00:50:39.011 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 09 00 13 18 00 00 02 00 00 FF
2015-12-30 00:50:39.012 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = SendData (0x13), type = Request (0x00), payload = 18 00 00 02
2015-12-30 00:50:39.013 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ]- NODE 4: SendData Request. CallBack ID = 24, Status = Transmission complete and ACK received(0)
2015-12-30 00:50:39.026 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ]- Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 04 03 70 05 C9
2015-12-30 00:50:39.028 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ]- Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 18 00 00 02
2015-12-30 00:50:39.029 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ]- Checking transaction complete: class=SendData, expected=ApplicationCommandHandler, cancelled=false
2015-12-30 00:50:39.031 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 0B 00 04 00 04 05 70 06 C9 01 DD 92
2015-12-30 00:50:39.033 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=1
2015-12-30 00:50:39.033 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2015-12-30 00:50:39.035 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 0B 00 04 00 04 05 70 06 C9 01 DD 92
2015-12-30 00:50:39.037 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 0B 00 04 00 04 05 70 06 C9 01 DD 92
2015-12-30 00:50:39.038 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 04 05 70 06 C9 01 DD
2015-12-30 00:50:39.039 [DEBUG] [ApplicationCommandMessageClass:38 ]- NODE 4: Application Command Request (ALIVE:DONE)
2015-12-30 00:50:39.040 [DEBUG] [ApplicationCommandMessageClass:56 ]- NODE 4: Incoming command class CONFIGURATION
2015-12-30 00:50:39.040 [DEBUG] [ZWaveConfigurationCommandClass:76 ]- NODE 4: Received Configuration Request
2015-12-30 00:50:39.041 [DEBUG] [ZWaveConfigurationCommandClass:121 ]- NODE 4: Node configuration report, parameter = 201, value = -35
2015-12-30 00:50:39.042 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveConfigurationParameterEvent
2015-12-30 00:50:39.043 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-12-30 00:50:39.044 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 4: Got a value event from Z-Wave network, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@4a0994
2015-12-30 00:50:39.085 [DEBUG] [.b.z.i.p.i.ZWaveNodeSerializer:107 ]- NODE 4: Serializing to file ./userdata/zwave/node4.xml
However when I try and set the calibration back to ‘0’ this happens:
2016-01-01 15:57:15.899 [DEBUG] [.z.i.config.ZWaveConfiguration:1091]- doSet domain 'nodes/node4/parameters/configuration201' to ''
2016-01-01 15:57:16.131 [DEBUG] [.z.i.config.ZWaveConfiguration:1177]- Set parameter index '201' to ''
but it doesn’t create the message to send to the device to amend the config. Is this a bug? Or is there another way to reset this specific configuration without factory resetting the device?
