franzda
(Franz Hauke)
1
Hello
do I have to pay special attention to Habmin chart editor?
Other components appear to be stable.
Also the chart display/widget in HABPANEL
HABMIN Failed to save the chart [object Object] and errors at configuration/ no reaktion
system environment
- openHAB 2.5.2 Release Build
- mariaDB for persistence
- opera Version:67.0.3575.31
- windows 10 pro 1909 Build 18363.657
- product: Raspberry Pi 3 Model B Rev 1.2
fr3sh
(none)
2
I have the same bahavior. Im using postgres, rpi3, on docker. Database are store the data correctly
fr3sh
(none)
3
I have found that I have error 500
{error: {message: “org.openhab.ui.habmin.internal.services.chart.ChartListBean”, http-code: 500,…}}
message: "org.openhab.ui.habmin.internal.services.chart.ChartListBean"
http-code: 500
exception: {class: "com.thoughtworks.xstream.mapper.CannotResolveClassException",…}
localized-message: "org.openhab.ui.habmin.internal.services.chart.ChartListBean"
I have same issue here with openhab2 and jdbc/mariadb persistence. Did you get a solution for your issue?
Rapti
(Leon)
5
I also have this issue. Running the current Openhab release build on Arch Linux ARM on a Raspberry Pi 4B.
Trying to save a blank chart, I get the following JSON back from the backend with a 500 status code:
"error":{
"message":"org.openhab.ui.habmin.internal.services.chart.ChartListBean",
"http-code":500,
"exception":{
"class":"com.thoughtworks.xstream.mapper.CannotResolveClassException",
"localized-message":"org.openhab.ui.habmin.internal.services.chart.ChartListBean"
