Installed habmin1 and i cannot save any graphs. It requires to assign an icon. But this list is empty. Do i need to put icons.xml somewhere else?
did you install the habmin-addon to the addons folder?
Yes copied that one. Didn’t copy the org.openhab.binding.zwave as already have a newer 1.8.1 version installed.
Ok finally some progress…
Got this in openhab.log
2016-03-03 20:14:01.145 [ERROR] [.o.i.h.s.icon.ItemIconResource] - Error reading XML file -
How can i debug it further?
The file is at least here /usr/share/openhab/webapps/habmin1/openhab/icons.xml
Even deleted most of the entries to make it simple (Had to remove “<” for the forum post)
!-- Icon set configuration for openHAB -->
iconset>
!-- Short name of this icon set -->
name>Standard
!-- Full label presented to the user -->
description>Standard openHAB icons
!-- Size -->
height>
width>
!-- Author -->
author>
!-- License information -->
license>
<!-- Icon list-->
<icons>
<icon>
<menuicon>bath.png</menuicon>
<name>bath</name>
<label>Bath</label>
<description></description>
</icon>
<icon>
<menuicon>bedroom.png</menuicon>
<name>bedroom</name>
<label>Bedroom</label>
</icon>
</icons>
So i am the only one having problems with this one?
Still trying to get a hold on this one as habmin is unusable without it
I had the same issue.
You have to name the directory just “habmin” not “habmin1”.
See the instructions of habmin:
Download the project zip file from GitHub and unzip files in the directory webapps/habmin (you will need to create this directory - note that the directory name must be lower case)
