I have openhab 1.8.2 running on a Intel NUC.
Before this setup it ran on a RaspBerry, but my SD cards got damaged frequently.
Openhab is running fine but Habmin is not.
It loads the page but Openhab status is offline.
I see the following in the logfile:
I have the org.openhab.io.habmin-1.7.0-SNAPSHOT.jar and org.openhab.binding.zwave-1.8.0-SNAPSHOT.jar in the /usr/share/openhab/addons directory.
openhab was installed using apt-get.
I tried with and without the zwave binding.
Both are not working.
Ther are a lot of 404 messages in the log:
“GET /services/habmin/config/icons?_dc=1464929709173 HTTP/1.1” 404 1461
Well, it will only work with the zwave binding, so no point trying without. You might also need the serial driver as well since that’s a dependancy on zwave.
I’m pretty sure that HABmin is not running - probably due to missing dependancies, but I can’t be sure of course.
This is a REST URL, so it’s not related to directories in any way.
I get the same result intermittently - habmin shows offline, and 404 errors on any request to the habmin services URLs. Sometimes restarting OpenHab resolves it for a while, sometimes it takes two restarts.
The zwave binding appears to be working - it logs messages when a device changes state (I’m just starting with zwave, so I only have one device to test with right now).
-rw-r--r-- 1 root openhab 1237582 Nov 5 22:45 addons/org.openhab.binding.zwave-1.8.3.jar
-rw-r--r-- 1 root openhab 1134175 Nov 5 23:21 addons/org.openhab.io.habmin-1.7.0-SNAPSHOT.jar
I’ve noticed twice that the habmin jar goes into a weird state and stays that way until openhab has been shut down for a minute or two:
-??? ? ? ? ? ? org.openhab.io.habmin-1.7.0-SNAPSHOT.jar
I’ve never seen this before – especially when logged in as root
