I have seen some screenshots of habmin1 … the z-wave administration possibilities seems far greater in this older version comparing to the habmin included in Openhab2?
Is it possible to install habmin1 on openhab2 … and if so how could that be done?
Hmm, in what specific case?
I have used HABmin1 with openHAB1 and am now using HABmin2 with openHAB2 and can do all that stuff I could do before.
Don’t forget you have the option to switch to “Show advanced settings” which will give you more options … maybe those options your are probably missing.
I’m pretty sure that does not work … and there is no need to get it to work.
From a ZWave perspective, it should be - there are other things that aren’t included in V2 like sitemap editing, but ZWave should have everything that’s in OH1.
