Hi, in my testings of openhab2 and habmin2, I could NOT, under habmin2, create an item and link it to the channel of my zwave device (after having unactivated the auto-creation under paper-ui).
=> habmin2 systematically throws a 404 error - nothing in log (restarting the system does not better)
habmin2 version : org.openhab.ui.habmin_2.0.0.SNAPSHOT-0.1.6.jar
openhab2 version : openhab-online-2.0.0-SNAPSHOT.zip (may 28)
==> is this an habmin2 known issue ?
So I tried to DOWNGRADE habmin2 to the release 0.1.5 … bad idea.
then I systematically get those logs, and habmin doesn’t work at all :
2016-06-04 09:52:31.767 [ERROR] [org.openhab.ui.habmin ] - [org.openhab.ui.habmin.designer(170)] bind method [setItemRegistry] not found; Component will fail
2016-06-04 09:52:31.775 [ERROR] [org.openhab.ui.habmin ] - [org.openhab.ui.habmin.designer(170)] bind method [setItemRegistry] not found
2016-06-04 09:52:31.851 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2016-06-04 09:52:32.023 [ERROR] [ui.habmin.internal.servlet.HABminApp] - Error during HABmin servlet startup
org.osgi.service.http.NamespaceException: alias: ‘/habmin’ is already in use in this or another context
at org.ops4j.pax.web.service.spi.model.ServerModel.addServletModel(ServerModel.java:130)
(I might have had a brief moment the 2 jars in the addons folder. But booting with either one no throws this message)
Only thing I could do to get it working again is … deleting userdata folder . Which is highly destructive. Is there another way to upgrade addons ? Do we have ANY way to interfere with OH2’s cache (with karaf command line that I don’t master ?) to clear things properly ?
