HI everyone,
after successfully playing with the demo environment (without habmin) I am trying to set up a minimal version on raspberry with HABmin2 to start with. After installing, I can not get the HABmin2 interface to run.
What I did:
- downloaded OH2 distribution-2.0.0-SNAPSHOT-runtime.zip from cloudbees yesterday
- deflated,
- dowloaded org.openhab.binding.sonos-2.0.0-SNAPSHOT.jar, org.openhab.binding.zwave-1.8.0-SNAPSHOT.jar, org.openhab.ui.habmin_2.0.0.SNAPSHOT-0.0.15.jar and copied them to addons,
- changed my http port in start.sh to 8081 (8080 is occupied),
- executed :/start.sh.
… no more no less.
Now everything comes up (using paperui I can see my sonos) , but calling the HABmin2 web interface (http://openhab2:8081/habmin/index.html) shows 404. Also ,on startup I see no reference to HABmin.As if it isn’t getting loaded.
What am I doing wrong ?
TIA&have a nice weekend
Peter
ps: Here’s the installation instructions from HABmin2 github
OpenHAB-2
For openHAB-2, download the org.openhab.ui.habmin JAR file from either the
releases folder or you can use the latest snapshot in the
the working folder and place it in the addons folder.
NOTE. Currently HABmin2 supports a backward compatible mode for the OpenHAB1 ZWave binding. Therefore
you must also install the OpenHAB1 zwave JAR into the addons folder. As soon as a OpenHAB2 ZWave binding
is available, this dependency will be removed.
Then open your browser at http://openhab server/habmin/index.html or follow the link from the OpenHAB dashboard
