I have experienced a faulty synchronization between habpanel and basicui during switch (ON/OFF - sonoff) command. this is happening only in one side, in a clear manner when I try to move the switch On\Off in basicui the habpanel responds at the same time with it. but in contarst no synchronization occurs with basicui.
it’s a normal a state or something got wrong?
Thanks.
It might be dependent on how the switch is implemented. One may postUpdate and the other might sendCommand. If you can check how the switches work are implemented it should show you which they use and then you can change one to the other.
