The chart widget isn’t correctly rendered if the device is changing orientation. Coming from portrait mode the actual chart is not filling the whole widget in landscape mode.
A manual refresh will resolve the problem.
[Edit]
Should I report this as an issue on github?
After doing an update I noticed some changes, however the rendering is still the same. See example:
The first one shows the chart after the device was turned to portrait. Note the chart extends over the widget.
The second one shows the screen after a reload (command from browser, not from HABpanel).
In this new version I noticed that scrolling isn’t working anymore. Is that intended?
Thanks for pointing that out, that’s probably a bug. I don’t have a solution yet for the automatic resizing of charts (and other widgets).
The locked down scrolling is probably due to the iNoBounce library to prevent the bounce effect on iPad, I should have another look.
