I have successfully installed influxdb w/ grafana and able to load data onto my HABPanel. I wanted to compare the default chart in HABPanel to a frame containing grafana data. Both are pulling from influxdb and using the same values.
I’m able to modify how the data is presented in grafana… but my data from the HABPanel chart is not averaged over time, and shows as spikes every minute. How do I change this behavior?
Also is there anyway to use a transform MAP on the data before it’s put into the sensor logs? for some reason my power management system shows .5 amps as 50 amps via snmp
This is currently working although my items must use a string value or else it will not work.
mark@mega-server:/etc/openhab2/items$ cat mark.items | grep current
Number strip_1_current "Current [JS(current.js):%s]" {snmp="<[10.10.121.6:public:.1.3.6.1.4.1.4779.1.3.5.5.1.6.2.1:60]"}
mark@mega-server:/etc/openhab2/transform$ cat current.js
(function(i) {
x = i / 10
Number(x)
return x
})(input)
