Not sure what I’m chasing, but I’m getting a JavaScript Error on Safari and Chrome on my OLD iPad (JavaScript 1.7, iOS 5.1.1).
When navigating to HABPanel UI, I simply get the Connection Lost! message. I understand this is probably the catch that JavaScript punted. I enabled the Safari debug console and indeed see there is an error under the covers.
From my research, it appears that there is possibly a ‘ng’ module inclusion issue here.
This could be a version issue with my ancient iPad, but I would really like to use it as a always on dashboard so if there is is a fix that would be awesome.
Yeah, but the Javascript is 1.7 and should be generally compatible. I think it’s just a bit more picky about its require statements. I hope there is a way to maintain compatibility. It would be a great way for a lot of people to put these devices to use.
A definitive statement on what JS is supported might help in this quest.
if (!Function.prototype.bind) {
Function.prototype.bind = function(oThis) {
if (typeof this !== 'function') {
// closest thing possible to the ECMAScript 5
// internal IsCallable function
throw new TypeError('Function.prototype.bind - what is trying to be bound is not callable');
var aArgs = Array.prototype.slice.call(arguments, 1),
fToBind = this,
fNOP = function() {},
fBound = function() {
return fToBind.apply(this instanceof fNOP
? this
: oThis,
aArgs.concat(Array.prototype.slice.call(arguments)));
if (this.prototype) {
// Function.prototype doesn't have a prototype property
fNOP.prototype = this.prototype;
fBound.prototype = new fNOP();
return fBound;
