First of all, thanks you for added Custom Icon option in HABPanel, In this way I don’t have to manually add custom icon set in your code each time I want to upgrade, this is great !
But, when I pickup an icon from the built-in list, the icon herit the colorize tag (class=“icon-tile ng-scope colorize”), but when I use a Custom Icon, the icon appear black (it dont have colorize tag (class=“icon-tile ng-scope”))…
Do you think you can add a tick box when you select custom icon to add or not the colorize option ??? Or maybe I missed something ??
Hi @MacFly - Fair enough, even though only makes sense for certain types of icons (those which are not already colorized).
It isn’t so simple since this would involve adding a new option everywhere where icons are supported (there are only 2 atm, one for the iconset and one for the icon). I’ll think about it.
I use some Eclipse Smarthome Classic icons, they have colors, and they will not be colorized by Habpanel, but when I use some icons from builtin icons set, they will be colorized by Habpanel. Is it maybe possible to apply same setting as Builtin Iconset when you use “Custom Icon” option ?
Can someone explain how can I replace an iconset in Habpanel? I found the jar (org.openhab.ui.habpanel-2.4.0.jar), emptied the existing iconset folder and fill it with new icons. After restarting openhab it still sees the old ones?! How?!
