I have setup habpanel on a nexus 10 tablet, as a home screen app (ie it is what comes up by default when the user opens the tablet).
It works OK, but when a tablet is inactive for a few hours, it becomes unresponsive (sometimes it even crash) for a few minutes.
I’ve seen something similar on my Android phone (Pixel XL). I added HABPanel as a bookmark on my home screen. When I first bring it up, it works great. I really like how it behaves like a native app. The problem occurs when I leave the app for an hour or so. When I go back to the app, it is unresponsive and doesn’t show the current status of buttons/switches/widgets/etc. I kill the app (pull up recent app list and swipe right) and restart HABPanel. It then functions properly again.
I’m also interested in any suggestions to fix this. Thanks!
I believe a similar bug on Android has been reported, if the device goes to sleep, the dashboards are not updated after waking up. I need to have a look…
Has this problem been addressed?
I have the same problem and right now Habpanel is not usable for me.
Habpanel on my wallmounted tablet (android 5) is unresponsive after a while, same applies to iPad.
To people using Android/Chrome, when this happens, I would appreciate it if someone could follow these instructions:
in short:
Enable remote debugging on the device
To access these settings, open the Developer options in the system Settings. On Android 4.2 and higher, the Developer options screen is hidden by default. To make it visible, go to Settings > About phone and tap Build number seven times. Return to the previous screen to find Developer options at the bottom.
Plug the tablet to a computer
Open Chrome on the computer
Hit F12
Use the ‘…’ menu and choose More tools > Remote devices
Click on your device on the left side then on the ‘Inspect’ button of the line correponding to your non-responsive HABPanel
I “fix the issue” withe 2 “solutions” ( I test both on different tablet )
First : Switch dashboard with item value. So i switch to the home screen with an openhab rule that send value every 5 minute then send empty value.
Pro : Built in and it work Con: it’s a crappy solution !
Second : put the habpanel in a ifram then ask html to refresh page every 5 minutes
Pro : full control of the html can add everything i want like a logo for the webapp. Con : need a web server, every 5 minute my tablet goes white because it refresh and it’s a crapy solution too
I know I know it’s just a band aid on the issue BUT !! my GirlFriend was mad that everything stop working ( I just migrate to Habpanel I used to have a web interface that look pretty much the same as Habpanel but with less possibility )
I managed to install everything so that i get an console output.
Now i have to wait for the tab to become unresponsive…
One first warning message i found was:
Handling of ‘touchmove’ input event was delayed for 2147483647 ms due to main thread being busy. Consider marking event handler as ‘passive’ to make the page more responsive. vendor.js
Ok, i got the logs… thank you for investigating
Another thing that seems weird is that the status of e.g. a switch is set from ON to OFF and then again from OFF to OFF…
Here are the warnings and errors as screenshoits followed by the log as a pdf.
Interesting and very strange. Normally it enters this piece of code only if the state actually changes - I’m wondering if there could maybe be multiple concurrent EventSources at some point.
You seem to have network issues in the errors screenshot, so you can’t receive updates while it’s in this state, not much we can do. However, it should recover nicely and start listening to updates again.
I have a few optimizations in mind already for this part.
The warnings should be unimportant, but the 2147483647 ms delay here is quite alaming This has to be wrong…
Thanks for the PDF as well, not much to see at first sight apart from what’s in the screenshots but there is Atmosphere-related stuff which is normally for OH 1.8 only!
i did the remote debugging but no errors.
just the inactivity screen of the tablet device
jwiseman
(Mr. Wiseman (OH 4.2 Snapshot on Pi4))
20
I’ve been struggling with this since I setup OH and 3 Android tablets on my walls since June. After changing all kinds of settings on the tablets; I finally realized what is going on.
The tablet is going to sleep and loosing it’s “refresh” settings within Habpanel. I have the weather up as my main screen with animated icons which is how I know Habpanel hasn’t refreshed because the icons stop moving.
Here’s what I did last night which is the first full night ever that Habpanel was still working in the morning.
Enable developer options and debugging
· Open the Settings app.
· (Only on Android 8.0 or higher) Select System.
· Scroll to the bottom and select About.
· Scroll to the bottom and tap Build number 7 times.
· Return to the previous screen to find Developer options near the bottom.
How do I Stop My Android Tablet from Sleeping?
In Settings if you scroll down towards the bottom directly under “Accessibility” you should see a “Developer Options” section
Inside this there is a Setting called “Stay Awake”.
Enable this and your tablet will no longer fall asleep on you
The negative side to this is the screen doesn’t ever go black but it does dim after a while.
