More info here:
Just waiting for merge to be approved.
With this script being loaded, sky is the limit now.
You can create your own Angular services/directives/decorators/etc
See above for an example script.
filename must be externalscripts.js inside your /static/habpanel location, which is my case is conf/html/habpanel (you need to create the habpanel directory)
