Habpanel icons not loading after refresh or startup
Hello together,
im new to openhab and after some time i finally managed to build my own wheather widget.
My problem now is that when i start the HabPanel the first time or i reload the page its looking like this:
wheaterWidget_issue
When i go to another page on Happanel and back to the icons page its working fine again.
To load the correct images from the weather information i made a case rule which handles all possible weather conditions and selects a fitting icon name. At the end its updating a string item which will be loaded in the widget. ConditionX is a string array to save condition names of all conditions with just one case (because there are around 50 cases)
The rule:
rule "Convert ConditionX to icon name"
    Item Condition0 changed or
    Item Condition1 changed or
    Item Condition2 changed or
    Item Condition3 changed or
    Item Condition4 changed or
    Item Test_WeatherIcon received update //debugging
    var ConditionX_IconName = newArrayList("","","","")
    for (ConditionCount=0;ConditionCount<=3;ConditionCount++){
        logInfo("Condition count:", ConditionCount)
        var String ConditionX_Case
        //save Condition state to 'ConditionX_case'
        if (ConditionCount==0 && Condition0 !== null){
        ConditionX_Case = Condition0.getState.toString
        if (ConditionCount==1 && Condition0 !== null){
        ConditionX_Case = Condition1.getState.toString
        if (ConditionCount==2 && Condition0 !== null){
        ConditionX_Case = Condition2.getState.toString
        if (ConditionCount==3 && Condition0 !== null){
        ConditionX_Case = Condition3.getState.toString
        //change condition state to lower case
        if (ConditionX_Case !== null){
            ConditionX_Case = ConditionX_Case.toLowerCase()
        logInfo("After copy Condition"+ConditionCount,"Content of count " + ConditionCount + ": " + ConditionX_Case)
            //change yahoo weather change to icon name
            switch (ConditionX_Case) {
                case "tornado":
                ConditionX_IconName.set(ConditionCount,"windy")
                case "tropical storm":
                case "hurricane":
                case "severe thunderstorms":
                ConditionX_IconName.set(ConditionCount,"thunder")
                case "thunderstorms":
                case "mixed rain and snow":
                ConditionX_IconName.set(ConditionCount,"light_snow_showers")
                case "mixed rain and sleet":
                case "mixed snow and sleet":
                case "freezing drizzle":
                case "drizzle":
                ConditionX_IconName.set(ConditionCount,"drizzle")
                case "freezing rain":
                case "showers":
                ConditionX_IconName.set(ConditionCount,"showers")
                case "snow flurries":
                ConditionX_IconName.set(ConditionCount,"snow_flurries")
                case "light snow showers":
                case "blowing snow":
                ConditionX_IconName.set(ConditionCount,"blowing_snow")
                case "snow":
                case "hail":
                ConditionX_IconName.set(ConditionCount,"hail")
                case "sleet":
                case "dust":
                ConditionX_IconName.set(ConditionCount,"dust")
                case "foggy":
                ConditionX_IconName.set(ConditionCount,"foggy")
                case "haze":
                case "smoky":
                case "blustery":
                case "windy":
                case "cold":
                ConditionX_IconName.set(ConditionCount,"temperature_cold")
                case "cloudy":
                ConditionX_IconName.set(ConditionCount,"cloudy")
                case "mostly cloudy (night)":
                ConditionX_IconName.set(ConditionCount,"nt_mostly_cloudy")
                case "mostly cloudy":
                ConditionX_IconName.set(ConditionCount,"mostly_cloudy")
                case "partly cloudy (night)":
                ConditionX_IconName.set(ConditionCount,"nt_partly_cloudy")
                case "partly cloudy (day)":
                ConditionX_IconName.set(ConditionCount,"partly_cloudy")
                case "clear (night)":
                ConditionX_IconName.set(ConditionCount,"nt_clear")
                case "sunny":
                ConditionX_IconName.set(ConditionCount,"clear")
                case "fair (night)":
                case "fair (day)":
                case "mixed rain and hail":
                case "hot":
                ConditionX_IconName.set(ConditionCount,"temperature_hot")
                case "isolated thunderstorms":
                case "scattered thunderstorms":
                case "scattered showers":
                case "heavy snow":
                case "scattered snow showers":
                case "partly cloudy":
                case "thundershowers":
                case "snow showers":
                case "isolated thundershowers":
                case "mostly sunny":
                case "not available": {
                logInfo("condition" + ConditionCount + " Icon Name:","not available")
                ConditionX_IconName.set(ConditionCount,"N/A")
            logInfo("condition" + ConditionCount + " Icon Name:",ConditionX_IconName.get(ConditionCount))
    Condition0_Icon.postUpdate(ConditionX_IconName.get(0))
    Condition1_Icon.postUpdate(ConditionX_IconName.get(1))
    Condition2_Icon.postUpdate(ConditionX_IconName.get(2))
    Condition3_Icon.postUpdate(ConditionX_IconName.get(3))
How i load the icon in the widget:
<widget-icon iconset="'custom-icon'" icon="itemValue('Condition0_Icon')" size="130"/>
I also tried to make the Condition0_Icon persistence with rrd4j as default, but no change.
gIconNames* strategy = everyUpdate,restoreOnStartup
I hope someone can help me, the rest of the widget running perfect and even includes dynamic icons.
  • Platform information: Raspberry Pi
    • Hardware: ARM Cortex-A53/RAM 1024GB/32GB
    • OS: Linux openHABianPi 4.14.62-v7+
    • Java Runtime Environment:
    • openHAB version: 2.3.0-1
After long time I finally found a solution.
Instead of:
<widget-icon iconset="'custom-icon'" icon="itemState('Condition3')" size="130"/>
I used this:
<img id="itemValue('Condition0')" src="/icon/{{itemValue('Condition0')}}.svg" width="150" height="150" />
Maybe usefull for someone else
Oh, this is probably because the widget-icon was designed to be reactive only to the state attribute, not to iconset or icon.
What you could have done instead is name your icons with a prefix then a dash and the dynamic part (see https://www.openhab.org/docs/configuration/items.html#dynamic-icons), for instance weathercondition-windy.svg, weathercondition-thunder.svg, and so on. Then something like the following would’ve worked fine:
<widget-icon iconset="'custom-icon'" icon="'weathercondition'" state="itemState('Condition0_Icon')" size="130"/>
Sorry I missed your first post…
