Hi is possible use habpanel in openhab 1.8?
tnx
Yes
Use the search function
i have read this message, i put habmin in the static directory,but when i go in http://myip:8080/static/habpanel i receive this message
Problem accessing /openhab.app. Reason:
Sitemap 'default' could not be found
do you have a default.sitemap
file in your configurations\sitemaps\ folder?
if your sitemap file is named differently, try:
http://myip:8080/static/habpanel?sitemap=YOUR_SITEMAP_NAME
(not sure if this will work… give it a try)
this is my sitemap
http://192.168.1.14:8080/openhab.app?sitemap=casa
i need put another file named default.sitemap in sitemap directory?
I don’t use OH1.x so I can’t test my recommendations…
does:
http://192.168.1.14:8080/static/habpanel?sitemap=casa
work?
yes
now i see a web interface at this addres
http://192.168.1.14:8080/static/habpanel/web/index.html#/
i try to work whit this
Huh? Are you sure? HABPanel doesn’t use sitemaps.
Yes i’m sure work whit this link http://192.168.1.14:8080/static/habpanel/web/index.html#/
I knew it… (that I was giving a wrong direction here )
The url that I gave (http://192.168.1.14:8080/static/habpanel?sitemap=casa
) is wrong since (like the author of HABPanel writes), HABPanel doesn’t use sitemaps…
Hi All,
Fresh clone of web folder to static. I can access habpanel however it states non stop that connection is lost retrying…
Also i cannot get a list of items…
I use a non standard port and OH 1.8, does this matter? do i need to change the port in HP from 8080 to mine somewhere??? Rest is available and working as i use it everyday…
Any help is appreciated!!!
NM needed to use the OH1 version… disregard…!
