since update to 2.2 my HabPanel Sliders (and sliders in other ui´s) for rollershutter doesn´t work anymore.
If i set them with basic UI switches (arrows up/down), i can see the new percentage, but if i move the slider in habpanel from 100 (closed) to 0 (open), nothing happens.
Jalousie (raffstore) are working, both, up/down and angle of lamella. Only my rollershutters don´t work anymore.
My rollershutters don´t work with slider anymore. Jalousie/Lamellas are working, only rollershutters are not working with slider. It worked in older openhab until 2.1. But since 2.2 not working anymore. I only can use the rollershutter switch with arrows up/stop/down.
It is not working in habpanel and not working in any other ui anymore.
I have knx actuators for my rollershutters/blinds/jalousie. I didn´t change anything there.
Is this the item, do you use for switch and slider in the sitemap?
Please post the item and sitemap-definition for one rollershutter as switch and as slider.
Are there any entries in the log?
So there must be a change in openhab 2.2 and above…
If the knx definition were faulty, then the switch in the sitemap wouldn´t work too? But i can move the rollershutter and i get the % showed in the sitemap. So i think, this is correct.
