Thank you for an inspiring widget. I’ve made some changes to the widget so that it fits better to my needs. I added the changed version to my OpenHAB modified widgets GitHub project.
Hopefully some of you finds my changes useful.
Brilliant! Any chance you could briefly describe the changes you made?
Cheers
Fraser Gillies
The changes are listed in README.md in the widget folder in GitHub: https://github.com/jannekalliola/openhab-widgets/tree/master/sonoscontrolwithart
widget/sonos.rules
) to increase and decrease volume. These can be used instead of chill and loud volume rules provided by Scootaash.Further, you can see the changes line by line at https://github.com/jannekalliola/openhab-widgets/commit/8641dd07370a4797f749446b18677e3107eb3edc
Do note that I’ve split the widget into three files. The originals from you were at the base and then I’ve made my changes that are highlighted on the diff linked above.
Thank you. Sorry, not good enough at programming to know how to use Github!
Those changes sounds like a great progression!
Nice widget, thanks! Seems like json file on top of the thread is a little outdated. I tried it first, then discovered GitHub repo. Thanks again!
can one explain to me where and how to define the media_player?
Hi I am very new to openhab is it possible to remove the Master on the volume control and just use it for one Speaker?
When I create the Items for the favorite playlist i get the error " ```
Error: Syntax error at line 1 col 12:
Switch item=
Unexpected equals token: “=”. Instead, I was expecting to see one of the following:
