i have a weird problem with habpanel .I thought it s easier to show you so i captured a video of the problem.
When i change dashboard for example from my vacuum to my livingroom dashboard ,and i press a switch widget right away,the item turns on and so the group that the switch belongs to.In the video i use “Living Lamp 1” that belongs to the group “livLights” :
Switch LivingRoomLamp1_Brightness "Living room lamp 1" ( livLights,Livlamps ) { ga="Light" }
Group:Switch:OR(ON,OFF) livLights "livLights" ( All_Lights ) { autoupdate="false" }
So as you see the first 2 times i change to livingroom dashboard and i press the living Lamp 1 switch and the livLights switch goes on and then off.This is wrong cause the group is in fact at the ON state but only in habpanel shows its OFF.If i refresh the page the state of the widget goes to ON which is right.At the third time i wait for a few seconds before i press the switch and it all works just fine .
I have tried chrome,firefox,fullykiosk browser and the problem is the same.I am on openhab 2.5.4 at a raspberry pi 3b.I have 255 item and everything else works just fine expept that little bug.
edit : it doesnt happen only for groups but sometimes for single item switches without belonging at any groups.I just used that example cause i can recreate it more easy.
