Those errors are weird. Have you tried forcing an update by uninstalling the extension and reinstalling it?
Also might be Safari-related, Could you also try in Chrome (refresh the page with the developer tools and paste the console output)?
Yes, I updated by doing bundle:update XXX
I might try doing a completely fresh OH2 install in a bit ⦠if this changes anything Iāll respond here.
It still doesnāt work, but here you go:
widgets.module.js:34 Registered widget type: button widgets.module.js:34 Registered widget type: chart widgets.module.js:34 Registered widget type: clock widgets.module.js:34 Registered widget type: colorpicker widgets.module.js:34 Registered widget type: dummy widgets.module.js:34 Registered widget type: frame widgets.module.js:34 Registered widget type: image widgets.module.js:34 Registered widget type: knob widgets.module.js:34 Registered widget type: label widgets.module.js:34 Registered widget type: slider widgets.module.js:34 Registered widget type: switch widgets.module.js:34 Registered widget type: template openhab.service.js:212 openHAB 2 service configuration loaded openhab.service.js:33 Loaded openHAB items index.html:25 Service worker not registered (not using HTTPS?): SecurityError: Only secure origins are allowed (see: https://goo.gl/Y0ZkNV). 2openhab.service.js:33 Loaded openHAB items 2chart.widget.js:97 datapoints=0 http://rambert.noip.me:8080/rrdchart.png?{{vm.imageQueryString()}}&h={{vm.height}}&w={{vm.width}} Failed to load resource: the server responded with a status of 404 (Not Found) openhab.service.js:33 Loaded openHAB items openhab.service.js:95 Updating Garage_Temp state from 13 to 12.9
I tried connecting to https, but then I got:
This site canāt provide a secure connection
rambert.noip.me sent an invalid response. Try running Network Diagnostics. ERR_SSL_PROTOCOL_ERROR
Looks like you donāt have any data! Perhaps you didnāt enter the right service provider in the text box.
Also you seem to have a rrd4j-style graph but it gives you a 404 error, maybe itās not installed.
Hiya @ysc
I have no idea about the rrd4j error - I donāt have any rrd4j graphs configured and I donāt use this persistency service.
Hereās what I have which works:
here thereās no message about datapoint, but I do get a warning about rrdchart.png.
And then I just change it to n3-line-chart:
and this doesnāt work (and I get a message about datapoints=0).
@Edward_Moyse:
Can you try http://[your_ip]:8080/rest/persistence to check and mysql is really there?
And also http://[your_ip]:8080/rest/persistence/items/gTemperatureSensors?serviceId=mysql
It might lead you to a deeper symptom.
Hiya @ysc - thanks for the reply!
I was pretty sure it was nothing fundamental, since the default graph works just fine:
Nevertheless I did as you said - for persistence I get
[{"id":"mysql","label":"mysql","type":"Queryable"}]
For the gTemperatureSensors query I get:
{ "name": "gTemperatureSensors", "datapoints": "0", "data": [] }
I presume this means I canāt use n3 for a group of values? Sure enough, if I change āOpenhab Itemā from gTemperatureSensors to e.g. FF_Hallway_Temp then it works!
If so Iām sorry for taking up so much of your time, but I had no idea! Perhaps you could add this info to the dialog? I can imagine there are other beginners who wouldnāt know about this limitation (especially since ādefaultā works fine).
RIght, I didnāt realize this was a group⦠n3 charts only work with individual items (for now), hence the āexperimentalā warning
Handling groups would mean getting values for every item individually, so it can be done - itās just not supported yet. More options for the graph widget (color, style etc.) will come eventually, when time allows.
Hi @ysc,
If I leave HabPanel open to my tablet, after a while it stop to update values, and I need to refresh the page into the browser.
Iām using Firefox for Android. I turn off screen after 1 minutes, but wifi never sleep and tablet is connected to power.
Any Ideas?
Marco
Are you running OH1? If so, I believe this is a known issue with OH1 not and issue with Habpanel.
Does anyone know of this problem also occurs with OH2 and iOS?
No problem here, but will try to reproduce.
Is there a feature request in GitHub for this? Iād like to see this feature too.
Thanks for building such a lovely HTML UI - Iām going to try and get it running on a 4" screen next week for use as a wall-mounted control center.
hi iįøæ playing arround with charts, here is an simple example for the linechart you usedā¦
<script type="text/javascript">
angular
.module('app', ['n3-line-chart'])
.controller('MainCtrl', function($scope) {
$scope.data = {
dataset0: [
{x: 0, val_0: 0, val_1: 0, val_2: 0, val_3: 0},
{x: 1, val_0: 0.993, val_1: 3.894, val_2: 8.47, val_3: 14.347},
{x: 2, val_0: 1.947, val_1: 7.174, val_2: 13.981, val_3: 19.991},
{x: 3, val_0: 2.823, val_1: 9.32, val_2: 14.608, val_3: 13.509},
{x: 4, val_0: 3.587, val_1: 9.996, val_2: 10.132, val_3: -1.167},
{x: 5, val_0: 4.207, val_1: 9.093, val_2: 2.117, val_3: -15.136},
{x: 6, val_0: 4.66, val_1: 6.755, val_2: -6.638, val_3: -19.923},
{x: 7, val_0: 4.927, val_1: 3.35, val_2: -13.074, val_3: -12.625}
$scope.options = {
series: [
axis: "y",
dataset: "dataset0",
key: "val_0",
label: "An area series",
color: "#1f77b4",
type: ['line', 'dot', 'area'],
axes: {x: {key: "x"}}
</script>
can javascript code executed by the template widget, how do i get an reference to the controller, that i can pass values to scope.data ???
thanks in advcance!
Lars
is it possible to convert the above example to code that can be used in the template widget ?
Injecting custom user code is not supported (and probably never will be because it is unsafe, opens a whole range of vulnerabilities - the angular compiler sanitizes templates by removing in-line Javascript).
To customize the chart widget the only option is to fork the habpanel code, and hack around in web/app/widgets/chart. Check out CONTRIBUTING.md on Github for pointers.
What are you trying to do?
first of all, i would like to have:
later on:
This piqued my interest and actually wasnāt that hard to do, a couple hours. So there:
To all using interactive charts, please be advised you have to reconfigure them, the model changed a bitā¦
looks great! how do i have to install ? snapshot and apt will install the new options ?
Wait for the next build @ https://openhab.ci.cloudbees.com/job/openHAB2-Bundles/org.openhab.ui$org.openhab.ui.habpanel/lastSuccessfulBuild/ then update w/ paper ui or habmin
