I have put it on my to-do list, but I can not make a promise on when I have the time for it.
Edit: @gerrieg, here is a test version containing screen monitoring:
https://github.com/vbier/habpanelviewer/raw/testJar/hpv-debug.apk
Thank you @vbier for the test version, but i canāt find any settings for the screen monitoring. Version is 0.9.19pre, is this the correct apk?
Sorry, i forgot to push. Now the new version should be there (0.9.20pre).
Works! But i have to use a Contact item. OPEN for display off and CLOSED for display on. Would a Switch not be better?
Switch terminology would be better, but I use contacts because they do not make users think that there is something to switch from openHAB.
https://github.com/vbier/habpanelviewer/raw/testJar/hpv-debug.apk 6
Hi @vbier, Iāve tried to install it from this url on my Teclast T10, but it says āThe package appears to be corruptā while installing apk file.
Iāve installed my current version from Google Play.
Cheers,
Kuba
If you currently use the play store version, you will have to uninstall that first, or wait until @miker makes 0.9.19 available in the play store.
0.9.19 does not have the screen monitoring, though. So if you want that, deinstall the play store version before installing the apk.
Latest Release:0.9.19 just posted to Play Store
@miker has given me access to the play console, which shows lots of app crashes. I am wondering that nobody yet complained about that. I already fixed the easy ones, but there are problems left.
I decided to try to fix as many crashes as I can (which is not so easy if i can not reproduce them) and then make a new release.
So in case you have a reproducible crash, please pm me or open an issue in the github project.
@vbier Iāve had a few crashes, but that was on an APK version from December. It worked out to be roughly one crash per week so I wasnāt too fussed.
Iāve now updated to the latest version from Google Play and canāt for the life of me remember which setting I need to use to turn the screen on with detection. Can somebody remind me of the setting I need to point to my OpenHab Item?
This has changed in the meantime. There is no setting any more for this. You need to configure a motion item in HPV and set up a rule in openHAB that sends the appropriate command to HPV when the motion contacts changes from OPEN to CLOSED. Check the in-app help.
See
OK, Iāve got a new string item and the existing motion contact item. I guess I need to write a rule to change the string value when the contact changes?
Adding an embedded Google Calendar link in a Habpanel frame displays correctly in Habpanel - when viewed in Chrome.
However, in Habpanel Viewer I only get a āblack frameā.
Can anyone advise on this?
Regards
/Daniel
Ok, I am anwering myself.
Did not think this throughā¦
In Chrome I was logged on to the specific account - hence the google credentials were in place.
To make it work in HabPanel Viewer, I have to make it public.
No need to make it public. See point 3 here: https://github.com/vbier/habpanelviewer/wiki/Embedding-external-content-like-Google-calendars,-Grafana-charts-or-images
I installed habpanelviewer 0.9.19 from the Play Store, but I canāt get the start_app to work.
It pops up in the command log in habpanelviewer, but with red text.
RESTART, SCREEN_DIM works like they should.
If I install the version 0.9.18 I works perfectly, is the command changed in the new version ?
The command I send to my item, and habpanelviewer listen to is,
START_APP cn.sibo.jack.offscreen
Hi all,
Iām using the connected indicator to monitor if the tablet is online or not and if the reported time is more than 2 minutes after the previous one, I consider this as if habpanelviewer has been restarted since it should report every minute. In that case I update some values to the tablet (screen state and screen brightness).
I notice that when the screen is allowed to be turned off, the connection indicator is not updated every minute.
I see this in my log files since it triggers the rule (time in milliseconds):
2018-05-28 00:34:52.167 [INFO ] [e.model.script.SendToTabAfterConnect] - Updated values of tablet since difference is 252129
2018-05-28 00:39:02.746 [INFO ] [e.model.script.SendToTabAfterConnect] - Updated values of tablet since difference is 250555
2018-05-28 00:43:24.089 [INFO ] [e.model.script.SendToTabAfterConnect] - Updated values of tablet since difference is 261315
2018-05-28 00:47:19.747 [INFO ] [e.model.script.SendToTabAfterConnect] - Updated values of tablet since difference is 235707
2018-05-28 00:51:58.769 [INFO ] [e.model.script.SendToTabAfterConnect] - Updated values of tablet since difference is 279003
2018-05-28 00:56:14.561 [INFO ] [e.model.script.SendToTabAfterConnect] - Updated values of tablet since difference is 255807
2018-05-28 01:00:17.010 [INFO ] [e.model.script.SendToTabAfterConnect] - Updated values of tablet since difference is 242457
2018-05-28 01:04:28.258 [INFO ] [e.model.script.SendToTabAfterConnect] - Updated values of tablet since difference is 251250
2018-05-28 01:08:28.813 [INFO ] [e.model.script.SendToTabAfterConnect] - Updated values of tablet since difference is 240544
2018-05-28 01:12:22.584 [INFO ] [e.model.script.SendToTabAfterConnect] - Updated values of tablet since difference is 233783
So the connection indicator is only updated every 2.5 to 4.5 minutes instead of every minute.
All power saving settings are configured correctly on the tablet.
Also, when I turn the screen back ON via the command item, the screen turns on immediately.
Is there any reason or cause for this behavior?
Thanks!
Greetings,
Frederic
There is no code in the app that would report values with larger intervals when the screen is off. This has to be some power saving feature of the OS.
Edit: the only explanation I can think of is that network access is limited when screen is off and that the app tries to update the item, but fails.
