mappings can be use with Text?
It’s a Switch form the network binding
This is really great.
Significantly more responsive than HabPanel view and looks nearly equally impressive.
I have a couple of minor bugs / feature changes I’d like to see.
1 - I want to drop the header / navigation (like here: Customizing Basic UI with CSS
2 - I’d like the content to wrap to the second column as soon as it gets past the bottom of the screen.(At the moment, content can easily go past the bottom of the screen on column 1, thus being out of sight) - my intention is to use this on a wall mounted tablet.
Of course I am not expecting you to code any of this, just suggesting as potential feature enhancements
The column wrapping code needs some more love indeed, it’s on my list. It works kind of ok for me but i’m aware it could cause issues with other sitemap layouts
Removing the header bar is as easy as adding “display:none;” to the “.mdl-layout__header” class in overrides.css
here’s the column-wrapping fix:
turns out this is actually a better approach than flexbox css
Top man - thanks, will have a look!
Looks great, can you also post /etc/openhab2/scripts/python/gcal/syncgcal.py.
Would love to see how your sync the calendar. Your rules seem to be using this but the github src code is missing it. Thanks!
just pushed an update. i basically rewrote gmail and gcal syncing, it now works with multiple accounts and the usual credentials/token.json stuff, i tried to do it in node.js at first but the google API sucks big time, so python it is:
when i’m done with the shellys and some other stuff, i want to implement event scheduling via gcal, to like control heating during holidays, etc
Looks awesome !
on which env this BasicUI is supported :
- Android Openhab application ?
- Android Chrome ?
- Windows Chrome local ?
- Windows chrome myopenhab?
it works in all browsers, local and via cloud, openhab app is something else
Really awesome i have upgraded to 2.4 just to get this awesome UI
i am really impressed, you are right. #basicUIisNOTdead
Before
After
could i ask you how Do you login to open hab outside your LAN from your phone ?
from myopenhab, i am getting the standard basicui -
is it possible to increase the font size and icon size.
i have updated the font size in the css but it;s not refreshed -
i didn’t understand the taskbar near to the clock
i have tried to hide it but it do not work
How do you retrieve the phone location and whatsapp status ?
i have see this item
String MQTT_Phone_S_PositionRaw "Raw Data" { mqtt="<[cloudmqtt:owntracks/XXXXXXX/a0001:state:default]" }
how syncgmail.js is triggered?
broadlink-mqtt: do you have only one RM ?
did you create a service ? -
syncgcal
not sure to understand how the openhab items are updated ?
how do you trigger this script?
- i have also restored your scripts but getting those errors
Thanks again
I just implemented event scheduling through google calendar to control heating, alarms, tts volume etc via calendar events. I had it running for a couple days and it’s kind of awesome, probably the most flexible scheduling approach i’ve seen so far.
(the grey entries are some kind of activity log, phone calls etc)
Hi, I tried to implement your super schema with very nice results
Only I got some overlap and some cut off like this all over
Am I forgetting some setup value ?
I’m on Windows 10 with Chrome and Firefox
Thank you @illnesse
Excuse-me, I got the following at inizialization startup executing JS233
“SyntaxError: /etc/openhab2/automation/jsr223/00_jslib/JSRule.js:2:35 Missing space after numeric literal”
This occur for every scripts present in directory …\Scripts…\
I also got the following error for the same Scripts directory
2019-05-22 18:39:42.909 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script ‘file:/etc/openhab2/automation/jsr223/00_jslib/helper.js’: :1:1 Expected an operand but found error
2019-05-22 18:39:43.257 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script ‘file:/etc/openhab2/automation/jsr223/00_jslib/PersistenceExtensions.js’: :1:0 Expected an operand but found error
2019-05-22 18:39:43.317 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script ‘file:/etc/openhab2/automation/jsr223/00_jslib/triggersAndConditions.js’: :1:0 Expected an operand but found error
2019-05-22 18:39:43.369 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script ‘file:/etc/openhab2/automation/jsr223/00_scripts/00_pre_startup.js’: :1:0 Expected an operand but found error
I run 2.4.0 on Raspberry PI and installed every extention required
Totally unable to managed the scripts myself
Thank you
Hi there, is there any new update? Thanks for sharing this nice UI.
BR
Sorry i have been busy with other projects the past couple months. I might get back into it when it gets colder outside Glad you like it!
Could you share the iconset used? Struggling to find something similar for my lightbulbs =)
Dear illnesse,
Great work! Thanks for sharing also the overrides.html and the overrides.css
May you also post your jquerycookie.js you are referring to?
Hi ! Would it be possible for you to push your latest update with the SVG floorplan to github ?
Thank you
